No, sorry. It requires soldering to get the driver out before it can be flashed. Take off the bezel, lens, and optic. Unsolder the LED wires. Unscrew the driver retaining ring. Then the driver should come out where it can be flashed. Repeat everything in reverse to re-assemble.
There isnât really anywhere to put flashing vias, since both surfaces of the driver are really packed with components. It was originally going to have optical programming, but it turns out that would take several hours to transfer a ROM and it would require removing several features to make room.
The more I see of this, the more I like it. Please put me down for a second one. Then I donât have to decide between emitter options, Iâll just get one of each! If it helps, the number for my first one is 1995.
Thanks, teacher. The green isnât great, but as we were saying before, at that low price, it wasnât too much of a risk. Maybe you will like the throw and tint just using higher levels.
Your welcome cabfrank. Yeah, no doubt at this price it was a true deal. A win/win.
And that is exactly what I am going to do, just use the two higher levels. It actually suits me quite well when the âgreen is goneâ.
Even 10% is not horribly bad. But below 10% truly suxâŚ. âto meâ.
Thatâs why I donât like the SST-20 (and LH351D) emitters Iâve tried. I mostly only use low levels, and they donât look good at those levels. Even when doing CCT mixing to pull the tint pinkward, it still looks greenish in the bottom half of the ramp. The FET portion of the ramp looks nice though.
OTOH, itâs a little weird that youâd see much tint shift on a 8x7135 driver. It should have fairly constant tint across all modes except moon, since theyâre all running at the same power with different duty cycles. But I suppose if the pulses have rounded edges instead of being true square waves, youâd still see some tint changes.
I thought that this occurs at all wavelengths? What Iâve read on the subject is that green is the brightest perceivable color to the human eye under all conditions?
Shaved LH351Ds are quickly becoming my favorite emitter, for single emitter lights at least.
Itâs drops the duv to nearly right on the BBL or below - depending on which bin you start with - lowers the CCT just a tad and makes them a bit throwier without any noticeable change in output to my eyes.
Iâve heard the same is true of the SST-20 but that theyâre also harder to shave/sand and I havenât tried either of these emitters in a TIR triple/quad where I think Iâd still prefer the SST-20 for a throwier beam.
For a single emitter light the 351D has a great balanced beam profile though. Hitting roughly 700 lumens in a Sofirn SF14 w/4000K bin from Mtn-Elec and the âDOGFARTâ 5000K has finally made me like my Neutron V3 after swapping out the terribly green and tint-shifting X-PL HD.
*I suspect that people on BLF overcompensate: if a tint has not the desired rosiness, they have learned to perceive it as greenish
*If compared next to a pink flashlight, it indeed looks green.
*light above the BBL looks uglier in low CRI than in high CRI
One more reason with flashlights in moonlight mode : Purkinje effect
Even if an ideal flashlight has zero tint shift over its different modes, you are going to perceive a tint shift with a particularly low moonlight mode.
Yes, the TIR in the CO1s will likely mix the beam differently than the reflector in the S2+.
Many LEDâs, especially in reflectors, have a significant tint difference between the hotspot and the spill, and my experience is this difference gives you a more obvious means of comparison to notice bad tint in part of the beam.
Iâd bet if the beam in the S2+ was diffused, the green would be less noticeable even on moonlight.
My experience is the opposite with the 219C. The original 5000K CRI80 is much nicer at similar slightly greenish duvs (~0.0030-0.0040) than the newer CRI90 variants. On a white wall at least.
