What did you mod today?
9294 posts / 0 new
Nicolaas
Scallywag wrote:
Nicolaas wrote:
That was quite interesting but now………………….back to modding! Actually I’m hijacking this from Djozz as he did most of the work. I’m good at working out ideas and doing the rough calculation; Djozz has the skills and equipment to make it actually happen. What did we do? Well, I had a Thrunite TN31 that was already converted to an aespheric, doing 649Kcd with a dedomed XP G2. I quite liked it but the led deteriorated after a while and at 549Kcd I decided it was time for further development. The light moved to my storage and, as soon as a very limited number of wavien collars came available (early 2018 I believe) I bought two of them. The size I bought nicely fits on the shelf of the TN31, with a millimeter or so clearance on all sides. This is quite important because a wavien collar not only needs to be in perfect focus to achieve optimal results, it needs to be perfectly centered above the led as well. I got a friend to drill the old led & ledboard out on a laithe and Djozz glued an old style XP G2 on a copper dtp board to the shelf. After that Djozz made a copper ring to fit around the dtp board. It’s function is to get the wavien collar on the correct height to provide maximum foton recylement. So to speak. It then was fixed in place with three generous dots of heat glue. The light color is not great – as expected – a dedomed XP G2 with a wavien produces a nice green/yellow tint but the throw numbers are excellent: we measured 1,308.000 CD @ Djozz. Translation: 1,3Mcd in a handheld size light; I call this a success! It’s a pencil beam of course, but that’s ok. It’s a fun light, not meant to have any practical use. And fun I do have with it! In the pictures you can see the various states of development, a comparison with other aespheric lights and a few beamshots. The closest high voltage pylon is at 134 meters (146 yards) and the one farther away is at 713 meters (780 yards). Below a small light, above to the right BTU Shocker (greenish due to dedomed XM L2’s), above that to the left Djozz’ BLF GT, on top TN31. The beamshot pictures are quite accurate; but they do not show that we had a slight fog just above the ground, causing the light to spread out a bit. Enjoy! Edit: sorry but I can’t somehow get the pics uploaded. Will ask Djozz for help.
Sounds like a fun time! I wish I lived near djozz, he keeps liking the same LEDs as me.
Any reason you didn’t opt for a White Flat (or other newer LED besides the legendary “old good” XP-G2)?
The reason is very simple: Djozz still had an old style XP G2 lying around and these can take 5,5A with no problem.
The white flats work on a much lower forward voltage which can cause problems with the driver.
As the TN31 is one the precious few light with magnetic switches I didn;t want to risk the driver.
Also, if you want to make full use of a wavien collar (200% light output) you need to use a dedomed led.
If you use a led with a flat dome (white flat, black flat, XP-L HI, XHP35 HI) the max afficacy you can get out of the led is maybe around 185%.
And yes, having Djozz at just 11Km away is nice, very nice. And he’s a nice guy as well, we get along great.
Cheers,
Nico
CRX
CRX's picture
Last seen: 1 min 25 sec ago
Cool DB, it was a laptop that died a couple of years ago so me being me had to take it apart to see if there was any interesting bits I could re-use, tons of wee resistors, screws etc and a big sheet of white film & slightly diffuse transparent polarizing film from the screen.
I actually used a piece of that in the SL.
djozz
djozz's picture
Last seen: 31 min 38 sec ago
Here are some pictures going with Nicolaas’ aspheric converted TN42 mod.
I used a precisely sanded to thickness spacer, made of soldered brass rings, clearing the led wires, for the collar to sit on. The spacer was glued to the shelf around the ledboard with Arctic Alumina Adhesive, the collar was precisely centered with the led on lowest setting (and sunglasses on), then glued on the spacer with Norland 64 UV-setting glue. The already glued collar was further secured with large blobs of high temperature hot glue.
Nico is holding the TN42, there’s also a 1 Mcd BLF GT, a 470 kcd 3xdedomed XM-L2 modded Shocker, and a hardly visible 160kcd neutral FT02. The pylon is at a bit over 100 meter to the base, also over 100 tall.
The other pylon is at 700 meter, I did not have a zooming camera (just my phone), but you can see that it is illuminated.
Nicolaas
Thanks for the help in modding and posting pics Djozz!
Grtz
Nico
Scallywag
Scallywag's picture
Last seen: 4 hours 58 min ago
Nicolaas wrote:
The reason is very simple: Djozz still had an old style XP G2 lying around and these can take 5,5A with no problem. The white flats work on a much lower forward voltage which can cause problems with the driver. As the TN31 is one the precious few light with magnetic switches I didn;t want to risk the driver. Also, if you want to make full use of a wavien collar (200% light output) you need to use a dedomed led. If you use a led with a flat dome (white flat, black flat, XP-L HI, XHP35 HI) the max afficacy you can get out of the led is maybe around 185%. And yes, having Djozz at just 11Km away is nice, very nice. And he's a nice guy as well, we get along great. Cheers, Nico
11km away, huh? You two must keep working on throwers until you can bat-signal each other Wink
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Nicolaas
[/quote]
I like the idea but I see two problems:
1) too many high-rise buildings in the way
2) it would require over 30Mcd throw capacity, that would require an aespheric with a 1 meter diameter main lens…….
So, I probably will have to look for other means to achieve this I guess…… Wink
Grtz
Nico
Agro
Agro's picture
Last seen: 2 days 12 hours ago
Grtz
Nico
If you want to see the signal (and don’t need to be illuminated) you need much less intensity. But to shine through the buildings…you need much more.
djozz
djozz's picture
A gamma-thrower! Where did I put my cobalt-60 and the electromagnetic gamma-lenses?
lumenzilla
lumenzilla's picture
Last seen: 19 hours 59 min ago
Tonight: damaged two optisolis LEDs and a Samsung.
contactcr
Last seen: 1 hour 31 min ago
This is my kind of WDYMT post. Sheared domes, bad re-flows, shorting wires. Keep up the mediocre work it makes the average modder like myself feel better sometimes after seeing 10 posts in a row of flawless carbon fiber wraps, custom lathe/mill projects, hand carved pills/centering rings.
CRX
CRX's picture
We just don’t usually post our f-ups Big Smile
Yokiamy
Yokiamy's picture
Last seen: 4 min 11 sec ago
@CRX, how true
I admit, we all mess up sometimes.
A couple of weeks ago i messed up a reflector
CRX
CRX's picture
Yesterday, like two hours and six or seven attempts to swap an emitter in an AAA sized light that should have taken ten minutes.
Yep this puppy had just about it all that contactr mentioned…
I was almost at the stage where I was thinking the greenish tint wasn’t so bad after all and I should’ve just left it be Big Smile
Swapped out a Luxeon v2 for a Nichia 219C.
Scallywag
Scallywag's picture
Nicolaas wrote:
like the idea but I see two problems: 1) too many high-rise buildings in the way 2) it would require over 30Mcd throw capacity, that would require an aespheric with a 1 meter diameter main lens....... So, I probably will have to look for other means to achieve this I guess...... Wink Grtz Nico
Oh gosh, I just mean visible cloud-bounces. Like the bat-signal. At 11km you're starting to get into earth curvature issues for straight line... And probably finding whatever the laser version of BLF is. I don't try to find it because I'd end up with blind for sure
Mike C
Mike C's picture
People should post more in the “What did you break today” thread… I like that one Smile
MRsDNF
MRsDNF's picture
Last seen: 1 day 1 hour ago
I’d be here all day if I was to post all my breakages up. Facepalm
djozz
djozz's picture
Yep, me too, just yesterday tried to build a lighted tail, there’s 6 0603 leds on it but I spent 11 leds (some projectiled on the floor and never found back) before I found there was a short somewhere in the Oshpark board that I could not fix. So I will start all over again with a new board, and probably another 10+ leds before it is finished. Tired
DB Custom
DB Custom's picture
Last seen: 1 hour 57 min ago
Oh ya just gotta love a bad board! (Not!)
CRX
CRX's picture
Oh, and I forgot to say that because there was a short to ground it also blew the tail switch Facepalm
This wee bugger Big Smile
Scallywag
Scallywag's picture
I think the "what did you break today" thread is super important for newer modders to see, especially if people like CRX, djozz, MRsDNF post there. When they bust something, it helps them feel better that these well-known modders break stuff too.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 11 min ago
Does this count as breaking something?
One of these days, Hank is going to get sick of my silly requests. But for now, he’s still indulging my flights of fancy.
For reference, I asked if he could do this, using all four of his SST-20 tints. And to my surprise, he didn’t say no.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 14 hours 54 min ago
Changed the LEDs in my Sofirn SP36 to XP-L2 4000K 90CRI with perfect color rendering.
Lumenmeasurement with Sony VTC6 at startup:
- Before: 6350 Lumen
- bridged springs with AWG20: 6950 Lumen
- new XP-L2’s: 5950 Lumen
More pictures: https://www.taschenlampen-forum.de/media/albums/sofirn-sp36-blf-q8-mini....
ToyKeeper
ToyKeeper's picture
I managed to get a picture of my bare XHP50.2 while it was on. This involved shining it through a slide projector lens onto a big sheet of paper, and taking a picture of the projected image.
When I take a picture of it directly, with the LED off, it looks like this. There’s also another flashlight shining into the reflector to illuminate things better.
If I use only overhead light, it’s less colorful… just some green shining in from a nearby Kermit-green wall.
lumenzilla
I actually was looking for that thread and couldn’t find exact keyword to search the link.
Will bookmark the link instead for future reference Facepalm
-X3-
-X3-'s picture
Last seen: 6 days 16 hours ago
From the dedicated XHP50.2 3V thread :
I opened my D1, to try a slice & dice on my 3V XHP50.2…
But as soon as I desoldered the LED wires, I saw that the dome was slightly lifted Tired
I think I damaged it when I removed the “butterfly” centering gasket that I used.
Now I have a UV/blue thrower that heats stupidly fast…
I measured 19A at start !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
djozz
djozz's picture
^ a blue thrower, very useful too.
Agro
Agro's picture
On your first picture it really looks like the die spacing is very uneven.
On the second and third picture that does not seem to be the case. Though the bottom dies don’t seem to line up…and the top ones don’t either.
djozz
djozz's picture
That is really nice of him. And it must be a nice tint now?
-X3-
-X3-'s picture
To blind someone maybe ? Evil
Now that’s TACTICAL !
DB Custom
DB Custom's picture
In my fairly elaborate Ham’r build the center SST40 has already had to be replaced once, the dedomed die surface got something on it and made a pile of ash, after which the light it produced was on the green side. I had put a domed SST40 in it’s place at a loss of throw but small lumens gain. Now, in testing my rebuilt light box, I found out Ham’r is reading significantly lower than expected, “only 20,000 lumens” in the now calibrated box. As it turns out, the SST40 in the middle isn’t working once again.
As this emitter is run directly off the original Q8 driver as the Master of 4 Slaves, it has to be a wire came loose to the SST40. Bond wires appear intact, no sign of burned phosphor, just nothing from the center emitter.
While this may sound comparatively easy to repair, it will not be… I sealed connections in epoxy then embedded them under Sugru, a silicone compound. The easiest repair would be if one of the leads on the MCPCB desoldered due to heat (those contacts are sealed but would be the least obtrusive to get at) If it’s at the driver it will require hours of work to get at to fix and reassemble.
Ah, the life of a modder! Silly
