One more reason with flashlights in moonlight mode : Purkinje effect
Even if an ideal flashlight has zero tint shift over its different modes, you are going to perceive a tint shift with a particularly low moonlight mode.
Yes, the TIR in the CO1s will likely mix the beam differently than the reflector in the S2+.
Many LED’s, especially in reflectors, have a significant tint difference between the hotspot and the spill, and my experience is this difference gives you a more obvious means of comparison to notice bad tint in part of the beam.
I’d bet if the beam in the S2+ was diffused, the green would be less noticeable even on moonlight.
My experience is the opposite with the 219C. The original 5000K CRI80 is much nicer at similar slightly greenish duvs (~0.0030-0.0040) than the newer CRI90 variants. On a white wall at least.
These are ’my impressions of this particular SST20 4000K 95+ CRI’, yours may vary.
[/quote]
Hi Teacher. I read that the lumen output with the specs your light has is about 600 lumens on high… Do you think that is about right?
thank you.
patrick
Here are the numbers Maukka got for that emitter
Hi saypat… I would say it is ’at least’ 600 lumens or a bit better on High.
I see BurningPlayd0h posted some test results & that seems to be about right according to his posted chart.
I can’t get to my ‘Lumen Tube’ at the moment because of some remodeling…. but when I can I’ll measure it & see what I come up with. :+1:
Yeah, the 219C 5000K CRI80 I have is actually pretty okay. It tends to make things look a bit lifeless, but overall it’s reasonably good compared to most LEDs I’ve tried. It doesn’t really look not-white during use, even though a camera tells me it’s greenish.
i hope this light is not too green at low lumens
If it is, the $1 swatchbook has minus green filter material, but really, the xpl version will just be poor cri with no particular greenness, and the sst20 or lh351d versions are going to be between yellow and green when you go hunting white walls and pretty okay otherwise. It should be fine.
Decided to drop in on the progress of these lights, anyone care to give a synopsis on how the evaluation samples are coming?
This is pretty off-topic, but anyone have any ideas how to make a strip of RGB LEDs work? There’s someone trying to make a fancy flow wand which draws things in the air while it moves, and I haven’t really tried to do anything like that:
Not totally sure if this is the best place to post this so please bear with me! So, I’ve found myself in an area where I have ZERO knowledge. I know nothing about what I’m trying to do here so I’m anxiously crossing my fingers hoping that after several youtube videos and articles that I’m on the right path. But now I need some more specialized expertise. I’m attempting to build an LED flow wand. For those who are wondering:https://shop.astralhoops.com/collections/wands/products/atomic-v-levita…
About more on-topic stuff though…
If I understand correctly, the optics might be in now… and then Neal is planning to send some lights for sanity testing to make sure nothing is broken. I haven’t heard any details yet though. Hopefully soon?
Shaved LH351Ds are quickly becoming my favorite emitter, for single emitter lights at least.
That’s something I still need to try. It sounds really promising. At least, it’s a good way to make use of those dog farts.
You mean like a neopixel strip or ws2812? 3 wires and all are individually addressable, lots of Arduino libraries out there for POV
+1 interested
… and the sst20 or lh351d versions are going to be between yellow and green when you go hunting white walls and pretty okay otherwise. It should be fine.
This gets quite tiresome. No, it is green in use as well. Tint with yellow, or green are, for me, not noticeable outside in foliage. However, it is very noticeable in use indoors, or outdoors in a more urban area. So unless you’re in the woods, it is absolutely noticeable.
/\ … Yep.
Mass production will commence after the QingMing Festival ( literally a day for tomb sweeping; but significantly a day for remembering past ancestors)
Leds to be used are the XP-L HI 3D .(~4875K)…as for the other led version(s), no definite news about them still.
Leds to be used are the XP-L HI 3D…as for the other led version(s), no definite news about them still.
Time to start putting some money aside! :money_mouth_face:
And to remember that I am running a GAW for a FW3A here
Thanks for the update tatasal !!
Whatever, I’ll swap the LEDs anyway…
But I don’t see how the price would be the same between XP-L HI and SST20…
Thanks for the update tatasal… :+1:
QingMing Festival this year is 5 April 2019 by the way.
I ’thought’ the XP-L HI was gonna be around $6 more per light. :question:
