Yup, correct. That’s why with full range of available, we can custom engineer by mixing those E21A. No longer dependent to 219B sw45k.
I’m taking another beamshots now, stay tuned….
Created a dedicated thread especially for this E21A mix: [Reference] Nichia E17A/E21A (2000K - 6500K, R9050/R9080, color) CCT and tint shots
[Clemence]
Is there any firmware supported CCT changing? Like planed in LT1?
I don’t know of any suitable dual-channel driver yet for a flashlight. Something like 3 or 4 x 7135 on each channel would do it, and then it could be paired with a quadtrix in an S2+ or Skilhunt H03 behind a frosted optic, or perhaps as alternative, in a D4 body. I wouldn’t mind trading the D4’s high output for a tint-shifting option.
I would be more than happy to have nonmixing dual channel programmable driver. One channel for a daylight led the other one for night time led. But this can be achieved by using 2 regular drivers in one light
30% OFF for all 219C, 319A, and 144AM LEDs
Can be combined with normal store discount coupon code
[Clemence]
I was just thinking about order 144AM and E21A from you, but I’ve seen, that VR16S1 is now out of stock
Could you please restock them?
I was just thinking about order 144AM and E21A from you, but I’ve seen, that VR16S1 is now out of stock :cry:
Yep later altogether will all those new boards
[Clemence]
staticx57:Clemence, since you have not made the triple e21a, can we wishlist individual addressable LEDs on it?
Done! It’s seriiies/parallel/iindiividual addressable
[Clemence]
Hi Clemence, are you still planning on making this board?
If the E21a works nicely with a Carclo triple I might try putting it in the FW3A.
Ryzbor:Any chance of sending a 2*3500K (d220) + 2*4500K (d220) = 4000K mix to Maukka? For replcing the green 4000K D240.
Osram has a desktop program that can take the individual measurements and calculate the resulting mix.
Osram ColorCalculator. Free too
Better late than never: thanks, I’ve played a bit with it but it’s very complicated however it helped me figuring out some stuff.
@Clemence, any chance of restocking the d220 4000K in the newest future?
what triple optic is good for an E21A / Optosolis ?.
possible?.
these any good?;
https://www.cutter.com.au/product-category/led-optics/carclo-optics/carclo-tor-optics/page/2/
thanks.
bump. anyone?.
so cant an E21A / Optisolis be in a triple ? 10507?.
possible?.
these any good?;https://www.cutter.com.au/product-category/led-optics/carclo-optics/carclo-tor-optics/page/2/
thanks.
Hi Clemence, what can you tell us about the 219F and 319B leds, apart from that no high CRI versions are listed?
I will send some 3000K and 5000K (both D340 R70) to you and hopefully you can forward few fresh 219Fs to Koeff. They have been sitting in my box for almost a month. Have no time to test them.
[Clemence]
bump. anyone?.
so cant an E21A / Optisolis be in a triple ? 10507?. optosolis:what triple optic is good for an E21A / Optosolis ?.
possible?.
thanks.
I don’t know. I don’t have any triple board yet to tell. Maybe you can find it online somewhere
[Clemence]
djozz:Hi Clemence, what can you tell us about the 219F and 319B leds, apart from that no high CRI versions are listed?
[Clemence]
I can do a led test sure
Koef has not been seen on BLF for 4 months, I will send some leds to him but he may not be into testing them at the moment?
clemence: djozz:Hi Clemence, what can you tell us about the 219F and 319B leds, apart from that no high CRI versions are listed?
[Clemence]
No problem, no need to send him if that’s the case. Let’s pop them Jos
[Clemence]
I have an AT WIZARD PRO 6500k E21A from Clemence. Great Light!.
I am considering swapping for a more 5600k Daylight white.
would I be right in saying it would mean a LED mix of say maybe 6500k 5000k?.
possible ?.
worth it?.
kind thanks.
would I be right in saying it would mean a LED mix of say maybe 6500k 5000k?.possible ?.
worth it?.kind thanks.
Better get another Wizard and put 5700K quadtrix E21A in it. Everytime you open the press fit bezel it will damage the bore.
[Clemence]
To those placing order approximately last week, please be patient. Last week I broke my pinky toe. It was hard for me to moving around since I had to keep it slightly level with my heart all the time. Otherwise it will bleed and creates pain. I’m much better now and should be able to work normally in one or two days.
[Clemence]
Take good care of yourself, Clemence
