No. At ~4200K, I find it’s already about as warm as I can deal with. If I made it warmer, it would look even less white. Even at 100 CRI, it would still look worse. Warm incandescent-style lights make my eyes hurt, literally.
I’ll enjoy my medium-CRI neutral white instead, thanks.
I did not mean to lower the total CCT. Rather - use 6500K exclusively as the cooling agent rather than the mix of 5000K and 6500K. It should arrive at about the same CCT with fewer low-CRI LEDs.
I view it like: mix 4000K and 6500K only, with a good majority of 4000K. If that’s not rosy enough, replace some 4000K with a mix of 3000K and 6500K.
Added a volt meter to my VC2S cause the dial sucks, problem is I think it never stops charging now so I may need to add a momentary switch. Idk anything about electronics so don’t replicate this terrible idea.
Keep in mind, though, that those meters are powered by the voltage source they’re sensing. That means that “charging current” will quite possibly never go low enough for the charging-IC to sense, “Okay, time to stop…”.
The charger will or at least should hold it in CV mode at ~4.20V, and not overcharge, but it just won’t ever show it as being topped off.
I put a 3v XHP50.2 in my convoy l2 (single cell) with the intention to make it more of a single cell Q8, didn’t work. still throws like a beast considering what it is. but i do like the slightly larger spot.
I’m not sure if i’m just getting used to high lumens (my edc has a ~2200 turbo) but it doesn’t seem that bright. maybe it’s the X6 driver? still waiting on a LD-A4
I found a cell which had been discharged to 1.8V. Out of curiosity, I tried charging it. Things went pretty well until it was nearly full, and then it refused to go up above ~4.12V or so. It just kept charging and charging.
So… that cell is basically dead. It may still be usable for some lightweight purposes, but I drew sad faces all over it to make sure I don’t forget which cell it is.
I found that even with the volt meter it does stop charging. I think the lower resistance batteries terminate quicker and maybe just the smaller protected ones take forever
Put a 3V XHP-50.2 in my TK61, the driver is cranking amperage safe for an XM-L2 so I need to address power level, not sure how to go about making the TK61 do the amperage this emitter is capable of… as it is it’s only doing some 2100 lumens.
I’m trying to install an osram white flat in a GT mini but the screw cutouts of the new 20mm pcb don’t line up. Should I just use thermal paste without screws?
Well for some reason the screw cutouts on my gtmini stock pcb are spaced equally whereas the ones on L4Ps 20mm 3030 board are closer together so there no way to screw the board in.
Ignore the super bad de-soldering job.
Aha, so holes for the wires and holes for the screws don’t all line up… Gotcha.
I only got a micro, so can’t say how the mini’s put together, but if the reflector pushes down hard enough on the pcb, regular thermal goop like AS5 should work fine. The reflector (and presumably centering spacer?) should keep it lined up and centered. It’ll “float” and self-center via the reflector.
