Thanks. I’ll have to re-check that. You’d think that any required fields would be highlighted if not selected, rather than simply preventing the “Add to Cart” button from functioning.
Default ceiling is 120 (click 31 times after prompt). Max ceiling (= turbo) is 150 (1 click after prompt). Not sure what level default floor is set to, but lowest possible setting is 1 click after prompt.
I received my Fireflies E07 Friday of last week and it has a strange issue that my Fireflies PL47 has never had:
I will take a video to show you what’s happening but when I ramp up to the top of the ramp (not turbo) the light flickers very heavily and rapidly once it reaches the top of the ramp. This happens if I keep holding the button or if I release the button as soon as it reaches the top of the ramp. The flickering happens most of the time and can last anywhere from 2 - 10 seconds.
It also happens if I save the top of the ramp setting as the memory setting and turn the light off then on again.
Like I said, my PL47 doesn’t have this issue and is totally stable once it reaches the top of the ramp
Get some 80-90% alcohol and clean any copper parts or non anodized metal (driver ring, tail pcb ring, springs, battery tube ends and finally your battery + and - terminal)
I receveid my E07 from fireflies webshop, clear anodize, Nichia 219B
Everything is perfect, it’s now my favorite flashlight.
I already have a ROT66 and PL47, everything buy from fireflies website and with Nichia 219B
Nichia 219B is my all time favorite LED for long exposure photography (light painting), it’s great to have 3 flashlights with the same LEDs
Thanks… cleaned it all and it turned out to be the female tailcap. basically turned a tissue jet black after cleaning and she’s functioning tip top now.
Still… I’m kind of surprised I had to thoroughly clean my 3 day old light… lol
It’s pretty easy to transfer stuff to/from batteries, your fingers, grease from threads, oxidation, etc. Your other lights might be dirty too and if they are lower power or different type of driver the problem could manifest itself differently or not at all. I just clean them no matter what. Some people also re-do the grease or apply a thin layer or stuff like this:
I received my EO7 today and noticed something strange. Only two of the aux LED’s on the switch is on. Why is this? See pictures. Help would be appreciated!
If the light was ON during the picture that is how it's supposed to work.
If the light was OFF do this (there is no low/high, only high/off I think):
Aux LEDs / Button LEDs
Some lights have aux LEDs or button LEDs. These can be configured to do
different things while the main emitters are off. There is one aux LED
mode for the regular "off" mode, and another aux LED mode for "lockout"
mode. This allows the user to see at a glance whether the light is
locked.
Aux LED modes typically include:
Off
Low
High
Blinking
To configure the aux LEDs, go to the mode you want to configure and then
click the button a few times:
Off mode: 7 clicks.
Lockout mode: 3 clicks.
This should change the aux LEDs to the next mode supported on this
light.
For lights with a button LED, the button LED typically stays on while
the main emitters are on. Its brightness level is set in a way which
mirrors the main LED – off, low, or high.
For lights with front-facing aux LEDs, the aux LEDs typically stay off
when the main emitters are on, and when the light is otherwise awake.
The aux LEDs on most lights only turn on when the light is asleep.
The light was off in the picture. When I turn the light on, the aux/switch LED’s turn off. There’s only an on/blinking/off option in the settings. Only two LED’s on the switch. https://photos.app.goo.gl/adtzmA91pPf58etz5
There’s a picture of the light when on and the UI sheet that came with the light.
