Searching for "Convoy S2+"-like with better cooling (for home use)
33 posts / 0 new
babca
Hi everyone,
I’m new here.
I’m searching for a light for home use.
(1×18650, floody/wider hotspot, 700lm+, no zoom, it doesn’t have to be too much compact, strobe modes not needed)
I own Convoy S2+ ($17) and quite like it, but the flashlight gets very hot and it appears that it doesn’t switch to lower mode automatically (or too late).
Could you recommend any alternative in the similar price range?
Something like Convoy C8+, but designed for indoor use, not for long throw.
Thanks!
I also own Fenix TK22 which doesn’t have any cooling problems at all. (However, it was much more expensive as well.)
ggf31416
Last seen: 7 hours 2 min ago
Sofirn SP32A v2. Steps down from turbo after 3 minutes and has temperature regulation to backup. Or anything with more mass than a Convoy S2+ without a XPL HI emitter to increase the throw.
If you don’t mind bad quality beam issues one of the boost driver budget XHP 50.2 flashlights (either the Sofirn or the Convoy model) should be floody enough and have enough mass and efficiency to avoid overheating at reasonable output while still be compact.
Yokiamy
Yokiamy's picture
Last seen: 11 min 20 sec ago
Convoy M1 or M2 will suit your need.
If you search around, there will be codes/coupons for discount Wink
The C8+ is nice, but not floody, very intense hotspot and not useful for indoor use.
  BLF
Omega_17
Last seen: 7 hours 42 min ago
I use my C8+ with a flood plug (its just a frosted glass) and its really good for indoor use and easy to remove for the throw mode.
pennzy
pennzy's picture
Last seen: 54 min 11 sec ago
Sofirn SF 36W handles heat pretty well and won’t break the bank.
https://www.aliexpress.com/item/Sofirn-SF36-SF36W-Tactical-LED-Flashlight-18650-Cree-XPL-Powerful-1000lm-5-Modes-Torch-Light-Pocket/32837333027.html?src=google&albslr=230295163&src=google&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&&albagn=888888&albcp=1582410664&albag=59754279756&trgt=296904914040&crea=en32837333027&netw=u&device=c&gclid=CjwKCAjwhbHlBRAMEiwAoDA34-u3KNEtv0BFXPLOgrVen7BmCQcTSArCq_UzjrfV2jyk3P9RJZkN5hoCkYEQAvD_BwE&gclsrc=aw.ds
Inkidu
The Convoy S11 has an impressive pill weight. And the reflector is fairly wide compared to its height. Although the 26650 battery (Shockli being a good choice) hasn’t been adopted by the most widely known battery makers. As apposed to the 21700. The S2+ 21700 will be out in few weeks as well.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 17 min ago
Get the C8, bug Boaz for some DCFix, go crazy.
I literally fixed the craptastic beams from my LuxPro lights, which all use XP-G3s, to get rid of the tight hotspots with urine-yellow coronas, to nice floody well-mixed beams that’re perfect for indoor use.
koziy
If your S2+ has the biscotti firmware, you could configure the flashlight to mode group 9, which limits output to 50% of maximum.
hank
hank's picture
Last seen: 16 hours 16 min ago
Quote:
Boaz for some DCFix
This will help a lot, in my experience making light output somewhat more floody and much more even.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 6 hours 58 min ago
Not to step on anyone’s toes, but DC Fix and other brands of static-cling privacy film are widely available on Amazon or at hardware/home improvement stores.
Boaz
Boaz's picture
Last seen: 14 min 9 sec ago
    Yeah but they don't have 8 different versions of diffuser film either .... unless you like plaid or paisley patterns.
You won't find what I sell stumbling blindly thru home depot .
   - No toes were hurt by your comment -
Lightbringer
Btw, think mine was the #7 that did wonders for the LuxPros. Nonsticky, wedged between glass and reflector, snug as a bug.
Just played with the 2×D light, what a nice beam now! Love
Was a hateful little circle with a thick uriney ring around it. Now? Nice diffused bliss.
ChrisGarrett
ChrisGarrett's picture
Last seen: 3 hours 10 min ago
Why not just order another Convoy S2+ with a 2.1A, 1.4A, or 1050mA driver board?
You can cut down on heat by running the lower driver currents and they’re cheap from FastTech.
You can even order your light with different tints, to set the mood you’re after.
Chris
Lightbringer
Or just turn it down to medium instead of high? LOL
That was my first and perhaps the most obvious question.
“Doc, it hurts when I do this.”
“So don’t do that.”
<shrug/>
JackJax
JackJax's picture
S2+ turned down to a lower output, maybe even add a TIR lens.
I enjoy my Emisar D4’s for indoor use (not on turbo, of course).
Lightbringer
Oh, and a TO46R is nice and floody in the same form factor.
Boaz
Boaz's picture
Lightbringer wrote:
Btw, think mine was the #7 that did wonders for the LuxPros. Nonsticky, wedged between glass and reflector, snug as a bug. Just played with the 2×D light, what a nice beam now! Love Was a hateful little circle with a thick uriney ring around it. Now? Nice diffused bliss.
 Yeah #7 is quickly becoming one of my favorites too . I just stuck some on my D10 Boruit headlamp and now the beam is perfect . #7 is like a very fine micro frosting... Glad it helped Smile
Lightbringer
Boaz wrote:
Yeah #7 is quickly becoming one of my favorites too . I just stuck some on my D10 Boruit headlamp and now the beam is perfect . #7 is like a very fine micro frosting… Glad it helped Smile
Had to think about that for a while… “hownahell’d you stick DCF on a TIR lens?!?”… ‘til I realised that I swapped mine, and the come-with is a reflector. Facepalm
Think I got the original #1 on the 2×D light, though. But on the 2×AA light (compared both side-by-side), it’s just as nice. The #1 still leaves it a bit “directional”, but the #7 spreads out the beam soooo nicely.
Back to the OP… I got a C8A and C8T today, just joined my C8 Army™.
Get the C8A (wider beam to begin with, brighter overall beam) and slap on some #7, and you’ll have exactly what you want.
babca
Thank you everyone for great tips and ideas! I’m sure I’ll end up with multiple new flashlights Big Smile
Don’t stop posting! Smile
Macka17
Last seen: 19 hours 2 min ago
Just get a C8 or C8+.
Leave most others that size for dead. in throw or flood.
In Their price ranges.
Depending on model you buy.
I have 5. ALL different. ALL great.
Plotthound
Last seen: 3 days 21 hours ago
I’ve got a bunch of S2’s . None of them get too too hot like I read about. Maybe because it’s colder here.
Since you said to keep posting:
1. Turn it down
2. Remove some 7135 chips, it’s easy.
3. Buy another one. Gearbest has them right now for 11.99 with 6 7135 chips.
TheIntruder
Last seen: 2 weeks 3 days ago
I hate that they glue their lights, but the SP32A v2.0 kit for 21 bucks and change after code from Bezos’ Emporium US is a nice deal for a very good all-around light.
That’s what I use around the house; capable, small and easy to pocket, and closest to an S2+. A C8 won’t fit in as many pockets, and can be made to have a better rounded beam, but why bother? It was built for and better suited to another purpose.
But what distinguishes the Sofirn is that is can take CR123A cells and be left or forgotten in a drawer or glove box on stand by as needed, without having the need to periodically refresh an 18650. That makes it much better as a “home” light for most average people.
FaintReality
For work and around the house, I like my Sofirn SF14 V2.0
Surprisingly bright and the 14500 battery (smaller than you mentioned) last forever.
I also have the Sofirn SP32A V2.0 but don’t find myself using much at all since the SF14 is in my pocket from 3am till 8pm ish.
justanotherguy
Last seen: 32 min 10 sec ago
Inkidu wrote:
As opposed to the 21700. The S2+ 21700 will be out in few weeks as well.
hmmm.. any links to a discussion or info on this one?
anyone in NE ILLinois into get togethers?
Omega_17
Simon talked about it but its not official yet.
JJSEA
Last seen: 8 months 1 day ago
How about Jaxman E2L?
Tumbleweed48
Last seen: 20 min 8 sec ago
I don’t know if they’re still available, but there is a Convoy S4 that’s almost a dead ringer for the S2+ except that it has a ventilated head. I have one, and it cools very well.
Lightbringer
Been kicking myself that I never got an S4 way back when. Seems to be sold out everywhere (FT/GB/BG/etc.).
Jack Kellar
Jack Kellar's picture
Last seen: 5 hours 27 min ago
Definitely agree with the M1. With an OP reflector, it has a very similar beam profile to an S2+ with a smooth reflector.
Don’t really agree with the C8+‘s assessment however. I use my C8 all the time indoors at 0.1% and 1% modes (Biscotti, OP reflector), and the C8+ is no different as far as internals go.
BurningPlayd0h
No, the reflector is much larger on the C8 and will have a tighter hotspot compared to the M1/M2 or MUCH tighter compared to an S2 when the emitters are the same.
Scallywag
Scallywag's picture
Last seen: 1 hour 24 min ago
Tumbleweed48 wrote:
I don't know if they're still available, but there is a Convoy S4 that's almost a dead ringer for the S2+ except that it has a ventilated head. I have one, and it cools very well.
Dang, those are actually pretty neat looking. I'd ditch an IPxx rating for the interesting looks on those for at least a couple lights.
I'm now imagining those being as popular as the S2+, and people swapping strange pills into them for the bling factor.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
