What did you mod today?
8546 posts / 0 new
The_Driver
The_Driver's picture
Last seen: 3 hours 8 min ago
@alberto:
You need a soldering iron with a large, flat tip, high wattage and, if possible, a tip with integrated heating element to solder the driver to the pill reliably.
bilakos10
bilakos10's picture
Last seen: 14 hours 9 min ago
I made probably one of the smallest / lightest 18350 flashlights with built-in charging Smile
Skilhunt M200 + Astrolux S43 18350 tube.
From left to right: Skilhunt M200, Jaxman E2L, Astrolux S43 (with S42S body and bezel)
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
-X3-
-X3-'s picture
Last seen: 22 hours 31 min ago
I made a 18650 S2+ triple SST20 FET driver, with a*18500* Jaxman tube Smile
I know this isn’t new, but I postponed this mod for at least 2 years, so I’m quite proud to have FINALLY took the time t do it Big Smile
From left to right :
  • Convoy S2 triple with 18650 tube
  • Convoy S2+ triple with 18500*tube and *18650 battery
  • Emisar D4 18650
  • Convoy S2+ 18350 with tube
Comparison pic between how far the pill screws down in the head. I used an S2 pill in the S2+ head (S2 pill is like 5mm shorter than S2+ one) and grinded some of the threads to allow it to screw farther. There’s no edge on the top of the pille either, it’s filed flat with a wet 1000 grit finish to get good thermal contact.
I used an BLF FET driver and it heats as fast as my D4… pulls around 13A from a 30Q battery.
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
djozz
djozz's picture
Last seen: 3 min 32 sec ago
Nice job X3. I did it by chopping off the top of the original pill in two pieces and soldering the ledboard on the now open end. So I had no shelf for soldering the ledboard onto but the edges are so fat, almost under the leds, that it is thermally still very sound.
gchart
gchart's picture
Last seen: 58 min 20 sec ago
Modified my cheap “18 watt” 6-LED light bar that I put on my mower for late-night mowing (or snow removal).
Swapped out the cool white XB-D LEDs for 5000K high-bin XB-H ones (XB-H is a XP-G2 on a 2.45×2.45mm substrate) Despite it being a 5 year old LED, I think it’s the newest and brightest for that footprint. I also swapped the R180 sense resistor for an R120 for perhaps 50% more current. Hopefully it can handle that.
Before
After
Scallywag
Scallywag's picture
Last seen: 19 hours 2 min ago
I took my Jaxman Z1 and put a 22MM-7135-DRV-AW with 13 7135s...
I need to replace the LED and remove a couple 7135s now.
I also took my dead EagTac D25C Ti and replaced the driver with a moonlight special. I went with 6x 7135s, and "Moonlight--->2%-->33%-->100%" as the mode order. I treat the 100% as a Turbo, and the 33% as a high mode, and the two are actually pretty close in brightness off my 650mAh Olight RCR123A. I also replaced the rear switch with a Omtem 1288 small reverse-clicky for convenient mode changes. No twisting for me.
This had previously been equipped with a Mtn-17DD fet driver, which was single-mode 100%. The driver was dead when I got it. I'm not sure what the switch was, but in testing it felt like a reverse-clicky with crappy functionality, but it may also have been forward. I just couldn't get it to cycle modes at all with that switch. It also came to me with XPL-HI V2 1A, which I like a lot. In such a small reflector, it kind of needs the HI in my opinion. The reflector also has a very slight OP texture.
The spring on my Moonlight Special driver was very stiff and too long for the host, and I ran into issues. I didn't have a good replacement (a very short brass button would have been ideal), especially with the driver being two-sided. So I stuffed it farther down into the pill instead of using the press-fit brass ring, and soldered it to the sides of the pill. It works great now, and I'm never gonna swap that driver anyway unless Zebralight starts selling stand-alone drivers as parts. I'm really happy with it now, as I'd started carrying my Olight S1 as a "backup" EDC to my normal 18650-rotation, and while this is larger (and comically close in size to my SC62), I can't resist the nerd-metal aspect of having a Titanium carry.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 51 min ago
Modified BLF KRONOS Special Copper X6….21700 tube
. Triple 3v 50.2 K2 1D 6200k
. Slight tweaking needed…. optics SUCK! Angry
KB1428 “Live Life WOT
contactcr
Last seen: 1 hour 22 min ago
Is that melted optics? If so never seen such a thing
contactcr
Unless you shorted something that current should be fine. You sure you didn’t have dirt on it? Before u trash it scrub it with alcohol and try again without the head on it
Scallywag
Scallywag's picture
contactcr wrote:
Unless you shorted something that current should be fine. You sure you didn't have dirt on it? Before u trash it scrub it with alcohol and try again without the head on it
Thanks, I'll give that a shot. I didn't run it very long on high power, less than 15 seconds per "burst". I have another white flat that I accidentally bought on a 16mm mcpcb a while back, and if this one is truly dead I'll just reflow it over.
djozz
djozz's picture
I made this contraption to be able to measure leds at a precise angle. The bottom section is a rotation stage that I bought on aliexpress, the rest is custom made. The middle section (the black painted aluminium thing) is made such that the led is almost exactly on the rotation axis. But it is all made with hand tools while it should be done with an end mill, so the centering is not sub-mm precise. Still it should be good enough for what I want with it.
This thing is planned to be fixed onto a rail of some kind.
I’m not sure what I want it exactly for, tint measurements I guess, it was mainly fun to make it. But it could be used for rather cumbersome led output measurements too, as a hand-operated goniophotometer.
The Sofirn C01 in the picture is for size reference.
ZozzV6
ZozzV6's picture
Last seen: 3 days 3 hours ago
Astrolux MF01 mod
Leds: 18x Samsung LH351D 5000K 90 CRI
Driver: Haikelite MT09R TA FET
MCPCB: Modded from 6S3P to 2S9P led wiring
Springs: Stock but 20 AWG wire bypasses in carrier and 18 AWG bypass on driver
Output: 20130 lumens
Intensity: 61200 cd
MRsDNF
MRsDNF's picture
Last seen: 4 min 27 sec ago
Looks good djozz. Taking it to the next step. Where do you hide this from the better half? Smile
djozz
djozz's picture
That is quite the monster, Zozz ! 20.000 lumen in 90CRI must be very impressive when lighting up a forest.
I keep my builds tiny so it fits in my dark hole behind the cupboard Sad
Chatika vas Paus
Last seen: 19 min 45 sec ago
Very nice Zozz. I also reflowed lh351d 90cri to my mf01 mcpcb, but can’t find some time to put it together
Lexel
Lexel's picture
Last seen: 4 hours 54 min ago
ZozzV6 wrote:
Astrolux MF01 mod
Intensity: 61200 cd
I highly suggest to upgrade to better or 2. SIR800 FET as this will also get very hot at those currents
DB Custom
DB Custom's picture
Last seen: 3 hours 37 min ago
In the spirit of “Because it was there” I put 4 White Flats in an E07 along with 3 stock XP-L HI emitters. Reduced the hot spot, increased the hot. lol
We are under warning for severe supercell storms with possible softball sized hail and even tornado’s, supposed to be a huge amount of wind, lightning, and some localized flooding possible. So to get prepared, I am running 8 lights with Anduril in Lightning mode, from a few hundred lumens to 21,300. Big Smile
TK-05, 2 E07’s, Ham’r, EOD20, SP03, and GT Mini as well as my Meteor. These are on the shelves in front of and above me, quite a show!
ZozzV6
ZozzV6's picture
Lexel wrote:
I highly suggest to upgrade to better or 2. SIR808 FET as this will also get very hot at those currents
When I replaced the FET in my MT09R and MT03 they both having the dim glowing led error. With original FET they were completely off.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 13 hours 27 min ago
I have this error on one of my Q8 with Luxeon MZ and stock driver.
DB Custom
DB Custom's picture
I would say to look at the 7135 for that dim glow, the MOSFET is turned off at low levels so any power coming through has to be due to the 7135 leaking. Wink (gut feeling, don’t know this for 100% sure)
Lightbringer
Lightbringer's picture
Last seen: 36 min 17 sec ago
Y’all replaced one FET for a different huge one (‘800 for an ’808)? Betcha leakage current when “off” is gonna be proportionately higher, too.
Ever stick a non-dimmable CFL bulb in a socket controlled by a dimmer, even if you don’t intend to dim it but just slam it on/off? Even when “off”, it’ll flicker at random, like having your own lightning-mode built in.
That teeny-tiny leakage current slowly builds up charge in a capacitor in the CFL, enough to just let it “discharge” with a quick dim pulse.
Can probably be fixed with a resistor across the LEDs that’d suck down maybe 1mA or so. So… 3V, 1mA, about 3kΩ oughtta do it.
That way even 0.1mA leakage current would tend to go through the resistor first, and not even let the voltage rise to Vγ to light the LEDs.
ZozzV6
ZozzV6's picture
None of those drivers have 7135. Just the fet changed and for the lower channel I even removed the small fet and still glowed. So I think Lightbringer has the answer.
Lightbringer
Yay! I win!
DB Custom
DB Custom's picture
Wieselflinkpro’s Q8 is what made me think of that response. Wink
kikkoman
kikkoman's picture
If the driver doesn’t have a gate pull down resistor (10k), that might fix it. It’s an ATtiny thing.
alberto7
Last seen: 6 days 9 hours ago
I built 2x Convoy s2+ with LD-4 Drivers. One with Nichia sw45 9080 and the other luxeon V 4000k.
I try both, and the nichia it does not look pink tint as other people say (not very impresive). Any form of check if the led is correct?
DB Custom
DB Custom's picture
Sometimes I launch off into projects that, in retrospect, I might should have not done. This last one is a fairly good example but not a total waste of time as it turned out.
Some background… my EDC light that I made from Scratch used to have the tight Khatod quad optics, I had bought several while at it as they came from England I think. The light morphed into a standard quad with LH351D emitters and the Khatod’s sit here unused. Stage 2 of the background, Will34 here on the forum was selling off some lights… I bought an X6 and Convoy M1 from him. Both of these were already modified, the X6 into a triple and the M1 a quad with a Khatod optic. Neither was really performing all that well so I rebuilt both of them. The M1 was somewhat oddly done with a T-Pad Quad MCPCB and what appear to be XP-G3 emitters that have damaged domes from the ultra tight Khatod optics. A copper plug and a top section of SS filled the head. No idea why SS, but it was in there…
I hadn’t worked on the lathe in a while, so it was a good project to refresh my amateurish skills. I had a piece of copper, WAY bigger than needed, so I carved it down. lol
I tend to like the challenge of making a heat sink that follows the internal lines of the head, and in this case, fully supports the optic all the way up to the glass. Big Smile
Like most optics, the Khatod has an injection mold protrusion which made me hand carve some space from the top to get the optic to seat fully…
But what emitter? I thought about using sliced LH351D in 80 CRI trim, but the entry to the TIR’s in these Khatod’s is quite small, so I chose to use 4 White Flat’s and built a new driver for em using a lesser MOSFET and A6 firmware.
Hot spot is defined, the little quad makes 2510 lumens at 31.5Kcd, pulling 18.5A at the tail from a fresh charged 30Q.
Seems like a waste of White Flats in a way, but it makes for a unique little light and overall I think I am happy with it. Smile
djozz
djozz's picture
Apart from the inefficiency of the White Flat compared to the bigger die leds (2500 lumen can be made with i.e. a 3V XHP50.2 with under 10A), it looks like a nice performing flashlight with a pretty nice beam.
DB Custom
DB Custom's picture
I may have to rescue the Flats and put sliced Samsungs in their place…
The_Driver
Colors should be very vivid (intensive).
The tint should become pink at higher currents (above 2A). This should be very noticeable when you compare it to another flashlight.
Where did you buy the Nichia?
