here is mine:
here is mine:
Ok… thanks for the info Blackbeard. You posted while I was typing & that explains why the Fenix Light email address I found.
…. Two good looking knifes!!
No problem Teacher, these are both great budget knives, I will probably order one of those Gocommas this week
The 910 Land will be here tomorrow & I’ll probably spring for a Ruike like yours above.
I think you’ll be pleased with the GoComma, I know I am. About an hour ago they were $9.99. They were bumping $16 for a couple of days last week.
Dang, I didn’t need to see that Ruike. I love a steel framelock.
I have this Ganzo and its a very good knife with axis lock but the fit and finish is rough, good for the money and the design (stolen from Ontario Rat) but far behind the Sanrenmu Land.
The Land 9103 is easily the best budget knife for the money! This knife is just perfect with excellent steel and should worth much more.
Gocomma knifes I don’t have any but they look like random noname cheap knifes and I really don’t like the design of them.
Sanrenmu = Land = Ruike = Real Steel = OEM for big knife brands
@ Omega_17 … Spend $9.99 on one of the GoCommas we are talking about & I bet you will change your mind real quick.
The fit n’ finish is much better than any of the Ganzos I have & as I have said before…. equal to any of my Benchmades & better than a few of them I am sad to say. Sad because I love my Benchmades… but it is what it is.
There is nothing cheap looking about the GoComma when you are holding it in your hand.
Okay, if customs is all good then I’ll skip the ganzo and check out the Ontario Rat, but the other two sound good.
Thanks everyone for your assistance!
I also love that GoCommas and can recommend them.
Can someone recommend a tool to sharpen knives?
Something not too expensive…
The only thing about the SRM Land 910+ and 9104 that I didn’t like was its weight so I just made cf scales for the 910+ and a single cf front scale for the 9104.
Never gonna do that again, countersinking ball bearings and washers on the inside and the screw head on the outside and then allign all the other holes was way too much work
I wish they’d do a G10 version with a fat G10 front scale though, tough enough for most jobs and much lighter than 2 steel liners, even when skelletonized.
I don’t know if it will break your bank but the best I’ve found for an all arounder is the Spyderco Sharpmaker.
@ Adahn Very nice work!! . . I bet that was a job getting that all lined up correctly….
A cheap sharpening option:
I have a couple of Land 910+'s and I love them. and yes I can see what others have said about the weight but I don't mind it ...I'm never left wondering which pocket it's in !
The go,comma might be worth having a crack at.
I believe flippers aren't the problem for AU customs, the issue might be that it's 'assisted'. It'd be nice if the sellers could disable the feature for us to just re-enable it when they arrive.
I don’t have one, but I have heard the Spyderco is very good.
I have stones, but I rarely use them now.
I have some crock sticks similar to these…
They work well & were relatively cheap compared to the Spyderco.
I have a couple of Lansky kits that I use if I need to reprofile an edge. It works well if you take it slow & pay attention to what your doing.
You can check out YouTube & see some how some people use finer grits of wet/dry sandpaper with great results. I have used this and it also works well.
You will probably laugh, but when I just need to touch up an edge; I just grap a dinner plate that has an unglazed edge on the bottom & use that.
If your not familiar with sharpening, whatever system you choose; the main thing is practice. Get an old kitchen knife & practice with it. Practice holding your chosen angle correctly. Practice until you can make that bad boy hair popping sharp. Then… graduate to your better knives.
Sooner or later you’ll be able to use the bottom edge of a dinner plate to bring back a hair popping edge on any knife.
edit for spelling correction
Yeah, practice is best when it comes to knife sharpening. Another important thing is to do regular maintenance so as not to have a need for more work later on. Less aggressive removal of material, no need to kill the blade.
Found the RAT2 for $50AUD locally so it might just be worth avoiding the hassle of customs and go local.
https://www.knifewarehouse.com.au/rat-ii-black-handle-black-blade-folder-ontario/
edit:: helps if I read stock levels
Thank you Relampago
I will probably go for Spyderco.
