I’ve used a version of that for a few yrs now.
The only difference being I bought a set of DMT Diamond Plates (that fit) in leiu of the “stones.
Does a great job so far.
Just kept the purple stone for polishing.
Gives a nice even grind for kitchen but a little iffy for smaller blades.
I still do them, with the plates. By hand.
Made up a angle “L”plate with base and several holes in vertical to give grind angles.
Couple of years back purchased a Ganzo G720 due to reviews on this site. Seemed to misplaced it a couple months back, but since I’m not a daily knife user and have 2 SRM 7063 AUC - LI at hand couldn’t be that upset. Right now I am however starting to miss it and am looking for a replacement.
What I liked about the G720:
- Weight, it was quite a chunky knife and felt good in my hand
- Size/grip, see comment above
Axis lock, I seem to hurt myself with a liner lock, Axis lock (or something similar which keeps my fingers away from the blade) is the way to go for me
Going through this topic I’m seeing some new brands like Brother and Fura. So I’m wondering; should I just go for the G720 again or do you guys know a better/good alternative?
I’d like to get an FH41 or FH51 (more my edc size) but why can’t they add a standard clip to the package?
And seriosly, these two examples have an extremely different main grind.
Once I’ve had 4 SRM 910 variants at my place (910+, 911, 912, 913) at the same time, the main grind and ricasso where exaclty the same.
Seems Ganzo is still not on par when it comes to consistency.
But ok, for $20 I might get an FH51 in smoked orange or w/e they call it
Deep carry clips always bite my palm when I intend to really use the knife, same with the SRM 710s non-deep-carry clip.
For me only simple tip-up clips are working. It’s fine that they offer those dc clips, I’d just like it more if they’d offer both.
A bigger variant of this clip design would work well I guess:
And if the clip holes would be as far to the butt as possible it would work even better but it could need a lanyard then.
Maybe like this even though I’m not happy with the angle. Drilled the holes myself so no one else to blame
Still I like the new Ganzos, esp. the FH21, FH41 and FH51 but I have so many folders that it’s hard to justify another purchase when you’re on a tight budget. On the other hand it’s easier to be nitpicky, sorry for that
OK… thanks for explaining. . I was just curious cause I like those deep carry tip up clips, they are a ’personal preference’.
No need to apologize for being “nitpicky” though… we’re all that about one thing or another. . .
