1st Patron???
Yes. Kaidomain states in their listing they are FB4, J4.
Intl-Outdoor states theirs are FB4, J5, and these are presumably the same that ship in Emisar lights.
The J5 output bin is suspected to tend to be slightly more green even within the same tint bin than the J4, so if you like your Emisars, then a light with J4’s should look as good or very slightly better.
You did good setting that up TK……
that’s just what you and folks that want to contribute needed……
I really like the …… “you should probably just hire me” tier ……
but will probably be on the “pay as you go” plan.
Lol, those tier titles are kinda clever.
coming soon!
coming soon!
I can see mine overe there.
Daaaaaamn!
I had to enlarge this beautiful pic!
For anyone interested in modding their FW3A with Nichia 219B emitters, I added a new build target for that purpose. It’s the same as normal, except the FET modes are limited to 50% power even on turbo. This should help prevent damage to the emitters.
http://toykeeper.net/torches/fsm/anduril.2019-04-24.fw3a-219.hex
It would still be a good idea to avoid using high-amp cells in that sort of light though… like, use a 35E cell instead of a VTC5A.
Also, thanks to goshdogit for providing a 219B triple board to use for this purpose.
Thanks so much, TK! So, would a Samsung 35E be preferred to a Sanyo GA in this application?
Those are pretty similar.
Maybe a Panny B 3400mah is the way to go since it has a lot of voltage sag, yet high capacity.
They’re very similar in performance. Doesn’t matter which one you choose.
And you shouldn’t worry too much about using the default firmware with 35E/GA either. I haven’t been able to damage my 219b sw40 board with it.
TK, you definitely deserve compensation for all your work. On the other hand, unless I am mistaken, the owl already determined it takes three licks to get to the center of a tootsie roll pop.
Another one for me ,please.
Just to hear a different thing: I really dig the dark clip that Lumintop came up with.
Yeah, the surface finish at least looks good.
Is it possible to limit the output depending on battery current?
On High current, limit it to 50%, at half or empty cell give full power. But this will be hard because of the battery-drop down on high currents.
Perhaps using different ramping tables for the fet-chanel and decide whether to use at battery-check or after hardware-lockout (losening the battery-tube).
I, for one, prefer the black clip.
I’m still looking for a good method for blackening my knives clips.
I don’t like chrome clips, but I don’t like paint either of course.
The Olight clips have been black for a while now, and they never chipped a single flake… I think it’s a heat treatment,I don’t know.
Anyway, I love the FW3A black clip !
I like the black as well-
I think the treatment is black oxide, or “blueing” a controlled corrosion process I’m not entirely aware of the chemistry and process though.
I would be great IMO if these clips are black oxide rather than paint.
If the clips are stainless than the treatment is black passivization - even better.
Lately I’ve noticed a new trend, and I’m not certain if/how long it’s going to last:
every time I see a new picture of the FW3A, it is even more beautifull than before.
Thnx TK!
