Jason,
Thank you for the info. It’s looking like the light and HD batteries are a really good deal. I’m feeling a lot better about Sofirn’s reflector choice too.
Jason,
Your reflector does appear rougher. Maybe if you duplicate Jason’s photo angle and distance since your photo is quite a bit closer? Who knows…
Nope, from that angle, my reflector looks identical to your picture.
Right, not a light orange peel. And while it does indeed work pretty nicely, it is certainly not the smooth mirror finish they promised in the OP. And the 70.2 doesn’t need any at all, unlike the 70 that came in the L6. I have modified quite a few L6’s with smooth reflectors and upgraded 70.2’s and they are very well received. Even the L2 with smooth reflector and 70.2 is an outstanding thrower with nicely focused beam. So that’s the one thing I wish they’d done here, given us the smooth reflector they said they were going to.
I have the light, it works nicely, but due to this one factor it’s not the light they said they were going to build. It’s really that simple. No orange peel needed. Certainly not this thick heavy OP they’re passing off as light….
Original Post, number one, as stated by Sofirn….
Once again to confirm other information. It’s much appreciated if anyone could help optimize for better reading.
1. size: 9cm big head, aluminum bezel
2. Smooth reflector, AR coated lens
3. LED: one XHP70.2, 5350-5700K emitter
4. 2*26650 long tube(sleeve for 21700),
5. tactical ring
6. Switch: tail forward clicky switch + side switch (with indicator as Q8)
7. Overheating Protection. Low Voltage Protection.
We got neither the AR coated lens nor the smooth reflector. A 74mm reflector opening is a HUGE difference from the quoted 90mm head. So there it is. It is a nice light, but it should have been a Great light.
I think you’ve completely missed several points. I don’t have time to correct all of them.
I'm actually a big fan of the light, except for the driver/ui. I like my OP reflectors on my 70.2s.
What's strange to me is the SP70 drawing so much less power on turbo.
Has someone gotten the driver out yet? I'm still considering returning it and waiting for the blf special edition, so I don't want to open mine up.
Hi there,
Sofirn asked me to help posting this information.
SP70 is now available on Amazon DE. You can get it for a discounted promotion price from April 28 through May 6, 2019.
SP70 flashlight only: € 50,00
SP70 kit-version: € 65,99
Link: https://www.amazon.de/Sofirn-Taschenlampe-XHP70-2-Helligkeitsstufe-Aktivit%C3%A4ten/dp/B07MSFVVSJ
How to get the code:
Please ask for your individual code via e-mail to eu@sofirnlight.com or send a PM to Sofirn on BLF.
Note:
1. One unit per order.
2. One order per customer.
3. The promotion will end once the target quantity is reached, the deadline has passed or the stock is depleted.
Hallo zusammen,
Sofirn bat mich, dabei zu helfen, diese Information zu posten.
die SP70 ist jetzt auch auf Amazon DE verfügbar. Ihr bekommt diese im Zeitraum vom 28. April bis 6. Mai 2019 zu einem rabattierten Promotion-Preis.
SP70 (nur die Taschenlampe): € 50,00
SP70 Kit-Version: € 65,99
Wie erhält man den Code?
Bitte erfragt euren persönlichen Code via E-Mail an eu@sofirnlight.com oder sendet eine Privatnachricht an den BLF-Account von Sofirn.
Hinweis:
1. Nur ein Artikel pro Bestellung.
2. Nur eine Bestellung pro Kunde.
3. Die Promotion endet sobald die maximale Menge erreicht, die Frist abgelaufen oder der Lagerbestand aufgebraucht ist.
It’s not strange to me. Most all factory FET drivers seem to perform a bit less than BLF drivers. Lexel, Tom E and Texas_Ace, etc… know how to extract the most power. They also use the best components which may not be available in China.
As far as why the SP70 driver is not pulling the same high amps as my L6, who knows. It might be related to the FET it uses or maybe there is extra resistance in the springs. 12A to 13A is nothing to sneeze at and it gets hot pretty quick.
I might swap the FET out with one from MTN E and see what effect it has. Maybe, I don’t know yet.
As for driver pics, Tom E just posted some. Maybe you missed it.
I haven’t missed anything Jason, I know very well what the target was and what we were promised. The only thing I don’t get is why you yourself are so set on glossing over the glaring deficiencies.
You can’t build a light to throw and then scrap the reflector based on white wall shots up close. Glaring rookie mistake. The further it can throw the more a dark spot will show on the wall at close range, that dark spot won’t focus out for at least 10-15’ if the light has really good throw potential coming from a big die like this.
Simple facts learned the hard way, by building hundreds and hundreds of lights.
Please don’t waste any of your time responding, I’d rather you go build something…
How does this light compare to Acebeam T27?
I think, you think, it was built based on the Kronos K70 targets. It was not. This is probably the source of your confusion.
Hang on, you didn’t even read what I said. Plus you also make assumptions about the distance.
For the record, one more time, this light was not built for maximum throw. If it was, we would have put an xhp35 hi in it. This is basically designed to be a factory hot rod version of the S70/L6. Higher output, better UI, more throw (not maximum) all from the factory, no modding necessary. Plus at an affordable price. We have met all these goals.
Jason, Dale...I don't mean to interrupt the little disagreement of yours but maybe we all can acknowledge and agree that the SP70 is Sofirn's first (successful) attempt to build a big XHP70.2 light. Thus, their experience might evolve in time when they develop the BLF edition that hopefully fulfills all of our highest expectations such as a big leap in terms of throw and more efficient components (e.g. Infineon FET, SMO reflector, dedomed XHP70.2, BeCu springs, AR coated glass, and so on...). I could also imagine Lexel to invent a nice buckdriver for the SP70 for a more regulated output. Personally, I was in hope Sofirn would have spent more time for testing the SMO reflector and the optimum alignment of the emitter to reduce tint shift and rings in the spill. Maybe this can be done with the BLF edition. For the discounted price of $ 50 or € 50 it's still a very decent result we now get to buy.
It looks like everyone missed post 2000.
I'd love to see anduril or narsilm on this.
Jason, thanks. I thought I remembered seeing some, but didn't know if I was getting it confused with other lights. Nice to see the switch is a separate pcb, and not attached to the driver as some lights do. Would be easy enough to swap something Lexel builds into it.
Also, for the led color temperature, the Cree Fried Egg™ is strong enough in the corona that I don't notice how cool the cct is unless I'm really paying attention to the spill.
These 2 remarks, made right next to each other, sound conflicting to me.
How can you tell that Sofirn made the right choice of reflector if you did not check yet if they did the focussing right on the smooth reflector, especially if both you and Sofirn found a hole in the center of the beam while we know here on BLF that the XHP70.2 makes a fine hotspot in a smooth reflector.
I do not think that a non-parabolic reflector can be a reason, never heard of any manufacturer making non-parabolic reflectors, there is no reason to do that other than screwing up CNC settings.
This is in no way an attempt to dismiss Sofirn’s first big thrower, I think that the SP70 does many things right, and the good price more than makes up for the shortcomings that it still has (finning could be more effective, reflector deeper and smooth, a real BLF-UI would be more attractive).
I know I posted these earlier, somewhere:
Oops, here, post #1957, and more info: https://budgetlightforum.com/t/-/52135/1957
Yes, Jason also linked it. Thank you both.
I forgot to reply to this part. Yes, 12A is nothing to sneeze at, and we're looking at something like 90 watts there. Although I'd disagree that it heats quickly. Between the power reduction of possibly up to 50% as well as what we're hoping to be better thermal mass, my SP70 is not a hand warmer like my L6 is.
I'm really excited to see your efforts with a new FET and Tom's efforts with an ATTiny. I just need to decide if I want to mod it, or if I trust Sofirn enough to get the BLF edition right. Well, not even right, because many would probably prefer slightly different features than me.
Other notes:
I just noticed the tactical ring thing by the tail spins freely. Weird!
My dual springs appear to be compressed enough to both make contact with Shockli 5500mAh button-tops.
The tactical ring is not threaded, it’s held in place by sitting on o-rings.
The way Sofirn explained it to me was that they could not play with the reflector height because the centering rings had already been made and having a new batch made would have created a big delay. So they had to chose an ugly beam or a pretty beam.
If adjusting the reflector height makes for a nice looking hot spot, then Sofirn probably has the time to have new centering rings made. I also hope they can make the SMO reflector the full 75 millimeter inner diameter. There needs to be a noticeable jump in distance between the two or what’s the point of the SMO.
I can actually think of a reason to use a non parabolic reflector shape. Since the parabola is based on a single point source, I can see were a really large emitter like the 70.2 might cause some anomolies. I’ll use the picture below.
Notice how a large emitter could potentially create anomolies in the hot spot? A very slight alteration in the reflector shape might eliminate the anomaly. If it does, why not incorporate that tweak to the shape?
Or maybe a parabola is fine, but this particular one is not focused properly? IDK.
My Lumintop Tool AA also has a colored spot in the center of the hot spot, but it’s yellow instead of purple.
Certain things are really strange to me. Like why is the SP70 SMO spot purple? Where is that color coming from? It’s beyond my understanding.
