13576 posts / 0 new
korkfoto
Last seen: 2 hours 17 min ago
Received coupon. Thank you!
Little drawback: 3$ more for standard shipping to Romania. But after all this waiting…
Ordered! Smile
FIAT LUX!
Relampago
Relampago's picture
I’d use my UV convoy s2+ to find the fake. Swallow the diamonds, beat the captors with the provided scale. I think that’s the right answer.
“Electricity is really just organized lightning”
― George Carlin
teacher
teacher's picture
goshdogit wrote:
teacher wrote:
DB Custom, have you got a link to those pictures??
Here they are on page 490 of the original GT thread.
Thank you goshdogit, that would be them!! Thumbs Up
PBWilson
Last seen: 1 hour 25 sec ago
oweban wrote:
ToyKeeper wrote:
I hope at the very least it was an enjoyable exercise, even if it wasn’t any better than spending a few minutes playing Minesweeper.
Er, I enjoy little puzzles like that anyway. I doubt everyone does though.
Like, we were watching a sitcom one night and they posited a puzzle. So when the show was over, I went to go work out the answer. I ended up staying up too late because it was trickier than expected, but by golly, I finally found a solution.
FWIW, the puzzle was this:
  • You are presented with a set of twelve identical diamonds, each one extremely valuable. Same size, same shape, same color, everything. Except one of them is fake, and it weighs more or less than the others.
  • Along with these, you also have access to a balancing scale — the “scales of justice” type with two hanging platters, so it can only tell you which side weighs more.
  • If you can determine which one is fake, you get to keep them all. Otherwise, you keep none of the diamonds.
  • You can only determine the answer using the scale, and you can only use it three times.
  • You must decide exactly which three measurements to make in advance, before you have actually measured anything.
  • You don’t actually get to touch the goods. Someone else does the measurements and lets you see the result of each.
  • The diamonds will only be given to you if you can prove that your method always works. They won’t give you anything if you guess which one is fake but can’t provide a reliable algorithm.
So, how do you figure out which one is fake?
Oh, and then they add in one more detail: If you like, you can double your payout if you attempt the problem for thirteen diamonds — but in that case, getting a wrong answer will land you in jail. So there is a harder version for those who are willing to play with higher stakes. Everything is the same except there is one more real diamond in the set, and you can also use one dummy weight which has the same mass as a real diamond.
Any ideas?
Oh man I’ve done this one before, but brain is failing me. Something like 1-4 vs 5-8, then one of those groups vs 9-12, then 1 and 2 vs 11 and 12 (those dependant on heavier/lighter).
I had a similar idea. Break them into three groups of four but then got confused about where to go after you compare the three groups against one another without running out of tries. Hmmmmmmm.
oweban
oweban's picture
Last seen: 6 hours 21 min ago
Yeah, not at my desk at the moment to work it out again, but I’ve definitely worked it out before in a repeatable fashion.
I do like the idea of the 365nm and violence though ;p
Random Dan
Last seen: 4 hours 22 min ago
WARNING FOR RIDDLE ANSWER ATTEMPT
I’m pretty sure this works, but I’m tired so I may have missed something. It also doesn’t seem like the most efficient solution, which is worrying.
-Scale 1—————Scale 2———-Aside
1,2,3,4,5,———-7,8,9,10,12——6,11,13
1,3,7,9,11———-2,4,6,8,10——-5,12,13
1,2,7,8—————3,4,9,10———-13
This should result in the following mapping, where L: left side is light, R: right side is light, and B: the two are perfectly balanced (as all things should be).
1 LLL
2 LRL
3 LLR
4 LRR
5 LBB
6 BRB
7 RLL
8 RRL
9 RLR
10 RRR
11 BLB
12 RBB
13 BBB
cephalofoil
I’m interested in ordering one if it’s not too late. Thanks!
ToyKeeper
ToyKeeper's picture
Last seen: 8 hours 32 min ago
You’re definitely on the right track… but it looks like you’re assuming the fake is lighter than the others. What if it’s heavier? This test can’t distinguish between #1 being lighter and #10 being heavier.
caplang
PM received.
Thanks TK and everyone who made this dream come true.
xevious
xevious's picture
Last seen: 12 hours 11 min ago
PM received, 3D model ordered. I was #1336 on the msg list.
Random Dan
I suppose it would have been wise to read the specifications a bit more carefully. I think I removed all the symmetric cases, although it still feels like I’m missing something. It worries me that I did not use the dummy stone.
-Scale 1———Scale 2———Aside
1,2,3,5——-6,7,8,11——-4,9,10,12,13
1,2,5,6——-3,4,9,10——-7,8,11,12,13
1,3,8,10——2,7,9,12——-4,5,6,11,13
1 LLL
2 LLR
3 LRL
4 BRB
5 LLB
6 RLB
7 RBR
8 RBL
9 BRR
10 BRL
11 RBB
12 BBR
13 BBB
Elrostan
I’m down for 2.
Alldale
Last seen: 7 months 2 days ago
In for 1. Thanks
Neal
Neal's picture
Last seen: 4 hours 8 min ago
3D version will start to ship today
lightblows
Thanks much to all who helped get this going. Especially TK. I did purchase 2 but would like to get in on the 2nd round of different LEDs. I would like to be able to purchase 2 more at the discounted rate when those come in. I am not exactly sure how that is going to work but if it means I am to comment again then consider this to be the post. Good luck all!
teacher
teacher's picture
Thank you for this update Neal as well as the others you have given. Thumbs Up
Thank you also for what you have done to make the FW3A a reality!!
Best regards….. Smile
M4D M4X
M4D M4X's picture
Last seen: 1 hour 28 min ago
it was posted several times, that the same code will work for the upcoming led variations Wink
if something changes Neal will post that.
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
oweban
oweban's picture
I’m #1387 on the list, just got PM, so that’s where it’s up to (for everyone’s info)
cormun
Last seen: 8 months 3 weeks ago
Can I be put down for 1? Hopefully I’m not too late!
oweban
oweban's picture
I think being put on the list closes in 4 hours (based on a reddit comment by TK) so should be okay.
KevinZA1988
KevinZA1988's picture
Last seen: 20 hours 23 min ago
Please put me on the list for one more. I would like the LH351D variant later. Thanks!
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
nfetterly
nfetterly's picture
Last seen: 6 months 4 weeks ago
PM system worked great! 3 lights on order.
Please put me on the list for 4 more…
Dannopiano
Dannopiano's picture
Just got the PM and ordered a 3D, I was number 1398 I think. Thank you so much, what a cool thing to see happen!
mortuus
mortuus's picture
Last seen: 1 hour 58 min ago
Got my pm, was on nr 1700 or so, thanks for all involved for making this happen so excited things are moving now! Smile
...where Frugal meets with Flashlight!
Bmg2514
In for 1.
oweban
oweban's picture
You were actually:
TK's list wrote:
1217 mortuus
once duplicates were removed Wink
http://toykeeper.net/torches/fw3a/privmsg.lst
Spiderlight
Last seen: 6 months 1 week ago
Will I get a tracking code after shipping?
mortuus
mortuus's picture
usually all orders from neals gets a tracking nr, atleast my previous order there have got one.
JasonWW
JasonWW's picture
Last seen: 16 min 11 sec ago
He already said yes.
Neal wrote:
every package will have a tracking number
Click this to go to signature links.
Ilumenati
Ilumenati's picture
Last seen: 1 day 7 hours ago
OK, I guess I’m in for one more, three in total. This one will be a later led variant.
Thanks,
