About the same.
Thanks BlueSword… I hate to miss out on something… This thing is pretty dam impressive for such a small light… !
What does 8 amp pulsed mean. Even if I use an ncr18650b or equivalent cell it’s still not safe for the osram 1mm??
I can sell a few prototypes
Price as usual is 12€
Anduril or NarsilM as firmware
shipping is 1.4$ from here untracked
5$ tracked with 25€ loss insurance
v2.0 I made some minor improvements from the original prototype
any recommondation what to change?
This allows the D1 to run the black flat LED, as proposed in this canceled project …correct?
IS this a difficult LED to pop in to the D1?
I am running a 300kcd GT mini right now………but…….
you can buy already soldered White flats from L4P website on proper 3030 DTP MCPCBs
Black flat need still insulation from MCPCB tobody
What’s the “L4P website” when it’s at home? Google seems ignorant of it.
He is a member here.
But D1 reflector is not prfect enough for white flats. You gain only 10-15kcd. And loose 4-600 lumens. You can’t set the focus right. I tried it and putted back the XP-L HI.
Lexel: justanotherguy:This allows the D1 to run the black flat LED, as proposed in this canceled project …correct?
Black flat need still insulation from MCPCB tobodyBut D1 reflector is not prfect enough for white flats. You gain only 10-15kcd. And loose 4-600 lumens. You can’t set the focus right. I tried it and putted back the XP-L HI.
so basically my black flat modded GT mini is the top gun right now?
I get a kick out of how much throw this little guy packs
Yes. I got 58 kcd if I remember correct in my D1. Now I have an Astrolux FT03 with WF1 and it made 452 kcd.
justanotherguy:so basically my black flat modded GT mini is the top gun right now?
I get a kick out of how much throw this little guy packsYes. I got 58 kcd if I remember correct in my D1. Now I have an Astrolux FT03 with WF1 and it made 452 kcd.
source on that FT03?
I made it. Modded the driver. Used an MF02 MCPCB which was perfect fit.
“WF1”
Wow, this is an abbreviation of “White Flat 1mm2” which in itself is a makeshift BLF-description of the Osram KW CSLNM1.TG led.
We surely give newcomers a hard time understanding what is going on on BLF
Zozz:“WF1”
Sorry for that but I always mistake some characters in the full name.
ZozzV6: Lexel: justanotherguy:This allows the D1 to run the black flat LED, as proposed in this canceled project …correct?
You guys keep talking about the D1 vs the Mini GT…
That’s not fair at all… The D1 is much smaller in diameter :person_facepalming:
Now if you want to compare the Mini GT to an Emisar product, talk about the D1S which this thread is all about.
The D1S reflector is superior to the GT Mini one, I own both and they both rock a Black Flat… better resut wit the D1S (but I prefer the aesthetics of the Lumintop…)
Guilty. Sorry for the confusion…
Is the D1S noticeably better, or just a bit?
Nothing you would see with your eyes alone, even side by side…
The luxmeter is the only judge, that’s why I prefer the GT Mini which is far more sexy !
