In which case you would have to identify thousands as K, and then Kelvin as a second K? So 4.485KK? You can’t assume the period point identifies thousands without the K (thousands) indicator, it leaves to much to the imagination and doesn’t clarify the exact 4885K color temperature. If you were talking 10.5K lumens then yes, that’s fine, but in this case it needs to be more clear.
Ok, additive for the BLF Special edition SP70… I have changed the factory MOSFET to an Vishay-Dale SIR404DP and replaced the leads with 16ga Turnigy. With spring bypasses made by using 20ga Turnigy wires inside the dual springs and by using Samsung 30T 21700’s I am seeing a start value of 10,500 lumens and a 30 second reading of 8700 lumens. I am pretty sure a good AR coated lens would enable more lumens out the front, need to check without the lens to see what may be happening with this clear glass…
Right, and I reckon we all pretty much know that… I tend to stumble on stuff like that because I take things literally, that fine line between black and white, right and wrong. I have never been good at reading between the lines. I got it, after looking at it a few times, so I guess everyone else will too.
If Lux Perpetua ever asks me to build him a light I’ll try to source 4.885 Kelvin emitters….
This lights OP reflector measures 74.3mm opening diameter and 48.4mm deep. This depth to width ratio certainly needs some improvement if a mirror finished reflector is going to be implemented for the BLF light.
Ok, I finally got a reading without the glass… the light with glass lens is making 10,500 lumens at start… without the glass it can do 11,220 lumens. so there is some 720 lumens being lost to the glass. I don’t think this is a huge deal and the glass is pretty good, I would like to see the 1.8mm thickness increase to 3mm though, at these diameters the glass can get broken easier so a thicker glass is warranted, or the use of a really good Acryclic with AR coating.
So how do they interpret whether 4,885 (four thousand eight hundred eighty-five), which is read as 4.885, is actually 4.885 (four and eight hundred eighty-five thousandths)?
Sorry Jos, I was not aware of this issue. I moved everything from post #2 and #3 to the OP. Hopefully, this will resolve any future problems with new posts.
Sorry Dale, I didn’t expect to cause that much confusion when talking about CCT and Kelvin as the base unit. However, I do agree with you that using points and commas as decimal separator can sometimes be confusing. ;-)
That‘s exactly the root cause. I‘m used to separate the decimals by a point, not by a comma. That reminds me asking the cocky question what the internationally agreed standard is. Point or comma? :-D
Haha...I‘d love to get a DB Custom 'one of a kind' with 4,885...sorry, 4.885K. :-P
I just wonder if my eyes would even notice a CCT that low. :-D
Dale, from this day forward I promise to keep in mind using no decimal separator anymore. Result: No confusion for anyone. How’s that? :-D
