We got us a Hot Damn Texas shootout here folks.
Y’all just need to meet up and fight it out with lightsabers and be done.
Or strap on bull horns and gore each other.
Whichever you decide on, be sure to record it for prosperity
Peace out
Peace out
I have good reason to believe an XHP70.2 can exceed 9000 lumens.
We also have to remember that Jason's L6 is sliced. My understanding is that slicing can knock off as much as 30% lumens, which would easily drop 8000 to 5600. As for the lumen tubes, there are so many variables involved that I'm not sure how we can ever know whose tubes are measuring accurately. I appreciate the efforts to make your tube more consistent with other tubes Dale, whether that's more accurate or not.
I was under the impression you sent your Manx Buggy tube to Toykeeper and built yourself a newer, bigger diameter one. I don’t really know what’s going on with your lumen tubes lately, plus it’s hard for me to remember any changes you’ve recently done.
The only issues I had with the Manx Buggy tube is that it wasn’t diffused so thrower lights would read higher than floody lights. Secondly was that the calibration ws based on an average of several lights factory ratings. Those 2 things go against the basic principles of an integrating sphere which is to diffuse and integrate all the light together and then measure that light level with accuracy.
It would help me to understand if I knew more about your setup. Are you still using the Manx Buggy 3.5” tube but with 1, 2 or 3 added diffuser panels? Do you set the light on a glass shelf? Do you have some type of setup to put around the edge of the light to keep it from spilling out around the edges? Does the sensor mount on a flat wall at the end of the tube or in a necked down piece to capture more light? If your using a 6” to 4” adapter, does it taper down smoothly or does it bounce a lot of light directly back into the reflector? What effect does this have on the readings? When using the calibration light with the adapter, is the light shining down the middle or does it shine down the edge of the opening so some of the beam hits the reducer and bounces the light back towards the reflector.
So you see, we are not using the same design lunen tubes so there could be differences in the response curve or differences depending of the beam shape, etc…
The Texas_Ace Lumen Tube may not be perfect, but it’s consistent. That’s one of the key design points. If it’s inaccurate, it’s inaccurate for everyone so there is still consistency. This is why a I tell people to not take lumens so seriously. Homemade integrating spheres are great for doing mods and measuring if you got an improvement or not. They are also great for comparing different lights in a person’s collection.
Don’t be bitter, we are all just trying to understand things better. How can your 70.2 light read so many thousands of lumens higher when the amperage is so close (19A to 21A)? This really has me scratching my head. I wish our numbers were closer together.
I’ve been thinking about making a beach ball sized (1 meter) integrating sphere with a barium sulfate coating and a higher end lux meter, but it’s still really expensive and a lot of work. I don’t know if I care enough to built it. Flashlights are cool, but I’m not a Flashaholic or anything. I use them for work, not collecting.
No, not sliced.
You can’t go by that. That was written before TA had any calibrated source for his Lumen Tube and it was reading about 30–40 too high. I can’t remember the exact number.
You also have to factor in that he’s measuring a raw led with no reflector or lens. If you put that same led in a flashlight, the output goes down based on how efficient the reflector and lens is.
I don’t see us fighting at all. We are just trying to figure stuff out. There are mysteries to be solved.
Sofirn SP70 is a reliable, beautiful light.
Was there a generic code to get the Sofirn SP70 discounted on U.S. Amazon. Or will Tracy PM me the code?
I had to PM the Sofirn account here on BLF.
Thanks for the heads up
Darkness
SP70
Are the Sofirn 26650 cells that are included in the kit protected cells?
No. They offer the older 26650 and the newer high drain “HD 25A” and both are unprotected.
Sorry for the newbie question, but should I leave unprotected cells in my lights when they are not in use? Is there a safety concern? Again, apologies for the naive question.
Thank you!
Joe
Mine did arrive. I have to say for $50 it’s surprisingly well built and really a good all around light!
It depends on the specific light. Some lights have very low parasitic drain and some don’t. If you aren’t going to be using a light for at least a few days then it’s best to mechanically lock it out. The SP70 has the tail switch to cut power. Some lights with anodized threads allow you to turn the tail cap half a turn to cut power. Lights with raw threads might require taking the battery out.
Some lights may take a couple of years to drain the batteries while other lights may only take a couple of weeks.
I lock out most of my lights mechanically. The ones I don’t are used pretty often and have very low drain. They also use protected cells.
All my lights using unprotected cells get locked out.
Thank you so much! What about the SP70, E07 and D18? Again, trying to learn without burning the house down. Your last post was very helpful!
The SP70 has a physical switch, so just turn it off.
The E07 and D18 have very negligible battery drain during lockout/no aux LEDs, so no problem there too.
If you want absolute certainty, just twist for a mechanical lockout on the D18 and E07.
I’m sure it was told somewhere but can’t find it. Does anyone know the driver diameter?
I got mine today, and I actually like it more then I thought I would. What are the lumens #s people are seeing? I just did mine.
W/litikola Black 26650’s fresh off the charger.
Startup is just north of 7k, to be exact 7045 LUMEN’s
And
@ 20 seconds its at 5855 LUMEN’S
I’m happy
