In for one!
[♛ FreemeGB] FireFlies E01 LUMINUS SST40W N5 5700K 2300lm Andúril 27100/18650 EDC Flashlight - ENDED
Is it only available in 5700K tint?
Interested!
Interested
Interested!
Interested
Just realized; why no AUX LED’s? This is Fireflies after all, it’s sort of their thing!
I’m still in, but it’d be a whole lot cooler if it had both forward facing AUX and switch LED’s to match the E07!
Will the switch led’s be fully controllable via FW or will it be like their others where 2 are always on and the other 2 controlled via FW? FF if you’re listening make all 4 switch led’s controlled by the FW please!
Only SST40 with cool white for initial batch. [quote=gpbeiew] Interested Will there be a Nichia 219B 4500K version? [/quote]
This is there first entry model with simpler design... Have to sacrifice some functions in order to cut down the price.
Can you ask that if they make them without any bezel or driver glue? They have a hystory about assembling problems so it is better if it is repairable. And also moddable.
List and links updated.
Interested
Is the code out for this yet? I did not get a PM.
I was assuming it had Aux Leds behind the optic… can we order them as extra cost option?
interested
The mcpcb is only 20mm, with the solder wires and everything, I dont’ think it would be possible to fit aux leds
Interested. Thanks!
Plenty of room
Interested
There is one code available now but is not quite i predicted. If you MUST have the light right now, i can forward to you today.
FF direct sale will be available in a couple of days time.
They need to do some accounting work before that.
