Interested
Interested.
Based on the Convoy L6 70.2 smooth reflector is it safe to assume the FT03 70.2 should be around 2200-2400 lumens with 400-500 meters of throw?
I’m also assuming we’re looking at an extremely fast turbo step down due to the very small amount of heat sinking/thermal mass?
Interested
Interested for NW
The SST-40 already does that amount of lumens with significantly more throw than the XHP70.2 would have so that would be rather pointless.
I’m guessing 3800-4200 lumen, which again is kinda pointless unless you want a larger hotspot in my opinion since the 3v XHP50.2 can reach the same output with the original driver and will have more throw due to being a smaller emitter.
Interested!
Interested
Interested.
Interested
Interested depending on performance and UI.
May be my first light this year.
I am in
interested
Interested.
Interested
Interested
U guys are way under. 5k+ - this should/hope will be a blf driver, fet based. I get 7k+.
Should be a TA design driver, so I would expect high oerf FET.
interested if it has a orange peel reflector and preferably 5A bin led
In for 2 please.
Interested dependin on output.
You can be honest here, no need to lie, we are all in the same “support group”
