Interested
Interested for NW
The SST-40 already does that amount of lumens with significantly more throw than the XHP70.2 would have so that would be rather pointless.
I’m guessing 3800-4200 lumen, which again is kinda pointless unless you want a larger hotspot in my opinion since the 3v XHP50.2 can reach the same output with the original driver and will have more throw due to being a smaller emitter.
Interested!
Interested
Interested.
Interested
Interested depending on performance and UI.
May be my first light this year.
I am in
interested
Interested.
Interested
Interested
U guys are way under. 5k+ - this should/hope will be a blf driver, fet based. I get 7k+.
Should be a TA design driver, so I would expect high oerf FET.
interested if it has a orange peel reflector and preferably 5A bin led
In for 2 please.
Interested dependin on output.
You can be honest here, no need to lie, we are all in the same “support group”
Actually that’s true. I needed to cut my spending in the fall and haven’t bought a light since then. Honestly….it was really hard initially. Still quite hard for like half year. Now….it’s OK. I learned not to desire mediocre lights. Or even OK lights. And ones that may be excelent but don’t match my needs well.
Actually since fall there was not a single must-have light release for me. F.e. I haven’t bought FW3A and I don’t miss it. I believe it’s great but for every of my uses I have a better light already.
This one….is not a must-have either. But I rarely use my Haikelite MT07S because it weighs too much. This should be able to produce a reasonably close beam with much smaller weight and still good enough thermals. And my financial constraints are going to get looser soon.
Still - feasibility depends on UI, unless it’s good I won’t buy.
And on performace - it surely will underdrive the LED somewhat but how much? If too much I won’t buy.
Fried egg beam somewhat worries me as well though. If it delivers both of above point I’ll still need to think whether this light is great enough.
Interested.
Interested depending on price.
