*BLF LT1 Lantern Project) (updated Nov,17,2020)
Please put me down for three more units.
That makes a total of four for me. Thanks!
Put me down for two, please.
I’m fine with either head, size wise, but I do have a couple of questions:
  • whether the white translucent plastic of the new sample head - as compared to the frosted clear plastic of the old prototype head - might affect the CRI of the light passing through it? The new sample head’s diffuser looks white to the eye, but it would be a bit of a bummer if white filler in the plastic happened to disproportionately absorb some crucial wavelength…
  • whether the larger new sample head might have a slightly wider-angle spread of light upward and downward compared to the smaller old prototype one? The reason that occurs to me is that the new sample head’s diffuser seems to sit closer to the edge of the metal above and below it, so there’s less of a lip that might intercept some light.
I will be asking then to reduce the opacity of the frosting of the globe/lens. As less frosting will not affect the CRI as much, and will also allow more lumens through, (a double bonus) I will list the changes soon to the production one over the test unit.
indeed the test unit lens is closer to the edges of the head and the mid section, which i like as it reduces any edge shadows and increases the illuminance angle directions.
This sounds like a win - win too. :+1:
Forgive me if this is a redundant question, but is there a user-interface diagram somewhere back in these 150 pages of posts?
There is a specification list posted in the OP, but for the operation of the firmware of the lantern’s modes, our team member Toykeeper is developing a LT1 lantern version of the Andruil software, (and should be a full schematic of the operation soon of the finalized production of the lantern user-interface.
Thanks for the info :+1:
The user interface will be similar to the first item in the linked post. What that does not show is the tint mixing commands. Also, that light is based on a single 7135 regulator plus a FET driver. The driver for the lantern is several 7135s, so the output is always regulated to the set level.
Great job on the video DBSAR. It was nice to see and here you describe the features. :+1:
The lantern is looking very good, really looking forward to gifting a couple to my sons.
These are the additions since last Sunday. Count is 1509 as of tonight.
Don’t forget to check that your BLF user name is valid on either one of the Excel spreadsheets linked in post #1. If your name is not correct then you need to send me a PM with the correct spelling otherwise you won’t be getting a PM when the buy goes live.
This check only needs to be done once.
Only send a PM if your name is INCORRECT
1522 weklund
1523 weklund
1524 Kingjohn
1525 kase
1526 superbob47
1527 Th558
1528 hueycopter
1529 bikedave99
1530 whitecitadel
1531 nydude
1532 Wyre
1533 Wyre
1534 Enelooper
1535 ActiveAl
1536 ActiveAl
1537 Flummi
1538 sarxsvt
1539 Pulsar
1540 ishak
1541 goshdogit
1542 goshdogit
1543 goshdogit
1544 j00ski
1545 j00ski
you may add a 0.1F supercap to the driver which is more than enough to sustan the bumps and also funftion with no battery
anyway a alntern is not meant to bump around much
Fireflies tested a 100uF cap added to C2 and it does not work good reducing bumps shutting the light off
Anduril can be flashed that it comes after a bump on last memorized leven, which will work well, the question is if we want this on the stock light or not
It depends. Myself I camp in 3 styles.
I often arrive by car and spend time in a tent - then size and volume are or secondary concern.
Or I travel with backpack, sometimes by foot. Then size and weight are critical, LT1 is surely too large.
There’s also one yearly event where I travel by car but leave it several km from the tent. Then size and weight matter but are not critical.
Overall…I like compactness. But I don’t really care much as LT1 is already quite big and heavy.
I assume that the final version will not have lantern-useless modes like “momentary” and “bicycle strobe”, but do we know yet whether it will contain the candle, sleep timer, lightning storm, etc?
I second this. Function before form.
While I’m at it, sbslider/Sig, would you please add two more for me please. Should bring the total to 6. Thanks!
Those modes may be useless for a lantern, but it makes me think that it would be useful to have a mode to attract attention in an emergency with long run-time. Whether that’s … - - - … or something else, there are probably others here more qualified.
(Edited my faulty Morse)
Very Good job on the Video, lots of information.
I like the idea of the 2 O-Rings for people like me why drop/tip over things.
I mixed a 3000K and 5000K in a lightly frosted quad TIR, resulting beam is this:
CCT = 3887K (Duv 0.0010)
Color Rendering Index (Ra) = 92.7 [ R9 = 68.5 ] R1 = 93.3 R2 = 93.7 R3 = 93.3 R4 = 93.7 R5 = 93.0 R6 = 91.5 R7 = 94.4 R8 = 88.4 R9 = 68.5 R10 = 85.2 R11 = 94.6 R12 = 79.2 R13 = 93.1 R14 = 96.4
Yxy: 2088.710557 0.386335 0.382505
It’s not the exact LEDs the lantern will have but it should be a ballpark number for when both channels are at “max”. This is a good result and lands very close to BBL.
Yes, there is definitely use for a beacon mode. And I’d like to see more of a true beacon, like many of the Nitecore lights. Beacons in current Anduril releases only implement something I’d call a “blinker”.
