[♛ FreemeGB] ASTROLUX FT03 XHP50.2 (3V) 4300lm 735m 26650/ 21700/ 18650 Flashlight - SHIPPED!
Interested
So how will this differ from the previous ft03?
Interested
Led will be XHP 70.2
Driver has to be different (Voltage is not the same) which probably means different UI.
Maybe OP reflector.
And that’s about it.
whats the lumen numbers on this ?
i agree that XHP50.2 3V is can fit in same driver.
i hope freeme can manage 2 choice
1.xhp50.2 3v on same driver depend not over 35dollar and
2.xhp70.2 with new driver 3X.XX dollar
Interested NW
interested in 1
interested depending on final specs
I think it may have a chance to shine across Lake Wackawanna! :smiley:
Intrested, love the sst40 version
interested Astrolux Ft03 CREE XHP70.2 version
interested
Interested
Thank you
So, I’m picturing something like a shrunken SP70. Wider hotspot at the cost of some throw? I’d definitely be down with that.
Much wider hotspot, and way less throw compared to the SST-40 version.
The XHP70.2 has a massive die compared to the SST-40.
Will this light be also running on NarsilM or anything else ATTiny85 based?
As far as I know the ATTiny85 based drivers are for 3V emitters only.
So, no.
Even more reason to use a 3v xhp50.2!
Interested depending on output and throw. (I’ll probably get one of the FT03’s, just not knowledgeable enough to know how this will compare)
