Recommendations for a full featured easy to use charger
Thanks everyone for the thoughts and suggestions.
Based on your recommendations, and further reviews of the chargers you’ve recommended, I’ve decided to go with the MiBOXER C4 or some variation thereof.
Just keep in mind, the C4 cannot perform discharge capacity test. Not sure if that was one of your requirements or not.
That to me would’ve knocked it out of the running immediately. I like my (Nitecore) i4, but that it can’t do said tests means I rarely use it anymore. :frowning:
I needed a charger to do the longer 21700 cells and I went with the Miboxer C4-Upgrade. One amp for all 4 bays, or 1.5A for two bays is adequate for me. I’ve been happy with it. I like that it has the option for 12v with a standard 5.5 x 2.5mm jack or can plug in an AC cord. The Miboxer Upgrade C4-12 only has 12v input which is fine by me too. I use a 12v power supply that can source more current than most wall transformers. Nice to be able to use in the car.
For discharge capacity testing, I have a dedicated capacity tester (a ZHIYU) and didn’t need it built into the charger. (but seldom find a need to use it anyway). The new Miboxer Upgrade C4-12 (now has two yellow buttons) wasn’t available when I got my C4-Upgrade. Still waiting for it to become available on Amazon.
That’s within spec, which is 4.15v - 4.25v.
All my chargers have slightly different termination voltages. I prefer the ones that terminate a little under 4.20v, but some terminate higher. It won’t damage the cells, but you’ll get maybe 10% less cycles from them. You’ll also get a bit more capacity out of them, though probably only 1% - 2%.
My Xtar X4 terminates around 4.18v. So, I don’t think Xtar is designing chargers to terminate high. It’s just the random variance in the chips that all companies use.
I think my next charger will be the SkyRC MC3000, because you can set the termination voltage to whatever you want.
Hmm, wondering if anyone’d want to try one of these for custom termination-voltage settings… :laughing:
It actually looks pretty good for that, as long as it’s consistent.
Apologies for hijacking the thread…
This C4-12 version 2. Does anyone have a link on amazon (I’m in the USA) for this charger?
What about this:
https://www.amazon.com/Battery-Charger-Rechargeable-Batteries-Universal/dp/B07GZRBRGX/ref=sr_1_3?crid=98EGZRY1TYSI&keywords=miboxer+c4-12&qid=1557938777&s=electronics&sprefix=C4-12+miboxer%2Celectronics%2C188&sr=1-3-catcorr
From my cursory search, seems the C8 is not a discharge unit, only a charge unit? Is the C4-12 V2 an “analyzer” the charger like the opus 3100?
As was mentioned a few posts back, it’s not on Amazon yet.
Correct.
No.
I use the sky rc now for most of my charging needs.
At BLF we have our own custom lights…but no a custom charger.
I agree there is not a single one that could do it all.
I would gladly buy such product. Maybe we could talk with manufacturers to produce it?…
That is an appealing idea Agro. :+1: I would be in for one too.
Besides finding a manufactor to do it, the biggest problem I see is us at BLF agreeing on which features to include on it.
There is only one feature we SHOULD include:
Being able to change the end charge voltage from 3,9-4,2V for lithium-ion cells.
That would make for the absolute best charger.
BLF SKYRC MC3000.
Sounds nice, but I don’t know if that would be very “budget” friendly.
What about XTAR or Opus for the BLF edition? Can we get the Vape folks on board? BLF/ECF Edition?
A SkyRC like charger would be cool. But if it has all the bells & whistles have them seperate from basic manually set function options.
OP wanted something easy to use. Is SkyRC easy to use?
Nope… not for me it isn’t. :person_facepalming:
That is why I said “SkyRC like” … big, robust, charge at least 3A x 4 bays, discharge at least 2A x 4 bays, active cooling that works, manual settings, easy & straight forward to use.
I would just as soon have no bells & whistles… but that’s just me. :wink:
Why not a BLF Miboxer C4-12?
Miboxer has been quite responsive on BLF.
A good Miboxer C4-12 with a BLF style UI and settable charge voltage cutoff would make for a dope charger.
OP already made his choice back in post #19……
I don’t care who makes it as long as it has what I want on it & is simple/straight forward to operate.
