Ohhh - that 4040 quad is not listed under his MCPCB's, so guess he doesn't sell them bare :facepalm:
Yep, I'm still confused bout the 4 dies as well.
And since a couple guys chimed in about running these at high amps, djozz is either unaware, or didn't take time time to update his OP, because reading the OP, everything is fine and dandy with the Luxeon V at up to 12 amps or so...
Certainly that L4P quad or triple seems to be the best way to go with these LED's, or, be sure you constrain the amps way down, under 6 I suppose.
I think Kevin is talking about Luxeon MZ, which is quad 4x2mm2 die LED. Luxeon V is single 4mm2 die LED.
MosX boards more than good enough for triples, quads etc. because no one run LEDs at absolute max. in those setups - difference between DTP and mosX is marginal when you run LEDs like XPL, Luxeon V at 50-70% of max. current.
Are all MosX boards aluminum? Guess so... From this listing on a Luxeon V quad, I had no idea a MosX board is alum - would have fooled me for sure...
I'm surprised in triple and quads you are saying alum is no worse than copper - think about it, quads have 4 times as much heat, though amps per LED is lower, but the heat is not reduced.
Here is a quick picture of my C8F with Luxeon V’s . You can see that one is only lighted half. I did not know that one-quarter and three-quarter were also possible. You can not see individual dies though, I do not know how the led is built up.
That’s fair enough. It’s just that as i was unknowingly tearing the dome off an XHP50.2 it looked like one quadrant was failing, then that three were failing with a similarity to your picture.
Physically it’s clearly one die (see page 5) but it seems internally / electrically it’s 4. This is from the STEP file provided by Lumileds, you can’t see it in this projection but these pads are on the top plane of the substrate.
I hadn't read through this whole thread, but I just skimmed most of it. I'll definitely limit my remaining Luxeon Vs to below 6A (assumed in the case of the D4) to prevent killing them. None have seen one-on-one time with a FET yet, so they should all be fine.
So out of 4 lights, 2 look like the lower one and 2 look like the first one. But one of the LEDs that look good is reading much lower amps then it used to.
