Sofirn SP70 Alone $50, PM for AMZ US CODE(LIMITED)
Sofirn 26650 HD 25A review
Official specs
Capacity: 5000mAh (min 4900mAh)
Continuous discharge current: 25A
My tests
Capacity: 4600mAh
They perform as good as a Samsung INR18650-30Q up to 10A.
Below graph is measured with my computerized Battery Analyzer at 5A, 10A, 15A & 20A
Your graph is not showing temperatures at all.
If it completed the 20A test without exceeding it’s max safe temperature (typically 80°C) then doesn’t that mean it’s rated for at least 20A?
I’m still learning when it comes to the max discharge curve. Does it always have to reach 80 degrees to show a max rating?. I’ve seen tests from HKJ that have bad discharge curves which haven’t reached 80 degrees and they’re too high.
I’ve tested 14500 cells and the curves and capacity at that current look terrible without 80 degrees being reached.
EDIT: If I’m wrong them I’ll alter my first comment
I edited my first comment. Everyone can make up their own mind as to whether the 20A is acceptable :slight_smile:
No. Magnets having poor resistance is a myth. The material has poor resistance but large diameter and short length means the total resistance is negligible.
This magnet is a 1.53 mm long AWG –1 (yes, negative) solid NdFeB core wire. Despite poor material this conductor has a resistance of about 32 µΩ. This means that with a light pulling 10A the voltage drop is ~0.00032V.
Note that the number doesn’t include contact resistance which is likely higher than that (I would love someone more knowledgable to chime in).
In this case: the adhesive layer is likely an insulator which breaks connection.
Try using the magnet on a cell in a battery charger that measures the internal resistance. You will see a big increase. I’m not sure if this directly effects the performance on a FET driver, I haven’t tried to measure the amp draw difference, but I assume it would.
That, plus the potential to move around if dropped and cause a short makes me not want to ever use them. I’ll just solder blob a cell or get button tops or solder on a button top.
20A at 64 degrees
25A at 70
Even though it didn’t hit the 80 degrees temp I don’t think it’s handling the 25A current well at all.
Keep in mind that my CBA has a voltage drop of 0.03V at 20A & 0.04V at 25A so it’s not spot on but works well enough to show performance
There is more of this battery conversation here if anyone is interested.
Subbing.
I will use Liitokala 26650 (5000mah specs), it’s ok ?
The older cyan and black are good cells (a good choice assuming you can solder blob them for series contact), the new blue 5100mah seem to be questionable. Like always, buy from a reputable store that does not sale fakes.
Here is a repost of my battery tests from a few pages ago.
Why ?
Black Liitokala have 65.8mm :slight_smile:
It’s perfect for Convoy L6 or Thorfire S70s. I use.
What is
? Pictures ? :slight_smile:
Thx
Just perform your own spring bypass. You don’t need pictures of the 8ga across the tail.
I have black and cyan Liitokala and neither make contact.
I checked it closer, it’s 10ga and 8” long. Leftover speaker wire. No big deal.
I can not understand.
Thorfire S70s: 74mm (head) xhp70 (3960lm) - 87000cd (680m) max
Sofirn SP70: 90mm (head) xhp70.2 (5500lm) - 89733cd (687m) max
Why ?
Are they equal at distance throw ? :person_facepalming:
No, the Sofirn SP70 is heavily underrated.
S70S is about 550 meters throw.
SP70 is about 860 meters throw.
You should never trust factory specs. Try to find good reviews where the lights are actually measured.
I wait for night and I try them.
Convoy L6 new vs SP70 :smiling_imp:
Make sure to post beam shots!
