[SOLVED]using Atmelstudio 7 to compile Anduril for D4 + Aux
5 posts / 0 new
Anthon
Last seen: 2 hours 22 min ago
Edit: problem solved and full anduril running in my D4 with aux port enabled. If you need the file Pm me
Hello
I’m trying to compile a full anduril build for Emisar D4
I’ve followed this topic to add the required lines to the code to enable de aux port in the driver
http://budgetlightforum.com/node/65593
However, I’m getting this error when trying to build the firmware: looks like the code is too big, removing something like bike flasher mode solves the problem and builds the .hex sucessfuly, but I want a full anduril
This is the error I get:
Quote:
anduril.elf section `.data’ will not fit in region `text’
region `text’ overflowed by 26 bytes
recipe for target ‘anduril.elf
ld returned 1 exit status
Could you help me? Toykeeper told me that I should be able to compile the rom changing the compiler settings, copying the CFLAGS values in the bin/build.sh script into the Atmel GUI to produce a smaller file. However I’m new with Atmelstudio and I don’t know how to do that
I will share the anduril.hex file once finished and tested in my D4
Edited by: Anthon on 05/24/2019 - 06:07
contactcr
Last seen: 1 hour 10 min ago
Anthon
contactcr wrote:
Here is your answer:
http://budgetlightforum.com/comment/1457826#comment-1457826
thank you a lot, you saved my day
I got the .hex
I’m going to try it tonight and if it works I’ll share it here
Regards
Anthon
Tested and it works
If someone needs the .hex, don’t hesitate to contact me
trailhunter
Last seen: 5 hours 32 min ago
how were you able to get this to work? I minimized code and still get the error
Quote:
[localhost anduril]$ ../../../bin/build-tiny85.sh anduril -DCONFIGFILE=cfg-fw3a.h
avr-gcc -DCONFIGFILE=cfg-fw3a.h -Wall -g -Os -mmcu=attiny85 -c -std=gnu99 -DATTINY=85 -I.. -I../.. -I../../.. -fshort-enums -o anduril.o -c anduril.c
avr-gcc -Wall -g -Os -mmcu=attiny85 -o anduril.elf anduril.o
/usr/lib/gcc/avr/4.9.2/../../../../avr/bin/ld: anduril.elf section `.text’ will not fit in region `text’
/usr/lib/gcc/avr/4.9.2/../../../../avr/bin/ld: region `text’ overflowed by 54 bytes
collect2: error: ld returned 1 exit status
