You donāt have to āthrow awayā those XP-L HIās, you can throw them to me.
Iāll take either flavorā¦ but that beautiful 3D tint is my favorite of the three.
If you do it let me know & letās see if we can work out a deal. :+1:
Too long a delay on shut-off? Man, tough crowd. Itās a fraction of a second. I donāt see any reason to be bothered about it.
Sounds like your tail cap isnāt locked down tight enough. Did you remove and reattach the tail cap? Nothing is glued down, so if something shifted it may be a problem. The button on my FW3A has no lateral movement. This light was released with no glue or potting, for the benefit of modders. Must keep that in mind. And because of this, QC wasnāt as thorough as with normal Lumintop production. Some people found debris in their lights. Many have had loose retainer rings in the head (easy to tighten though).
Calibrate your thermal config and that should help a bit with the heating.
This is not meant to be a massive thrower for many minutes. Itās too small & too thin for that. Itās a āmicro-18650āā¦ think about that. Canāt make big thrower demands on this form factor. Completely unrealistic.
Triple emitters means more efficiency. Which means youāll get longer runtime for the same output than with a single emitter.
The light is very nice, I was just giving some critical feedback after some time with it.
I did disassemble and reassemble the tailcap because it was not always responding to button presses, and that seems OK now. I will also check the head retainer ring.
Teacher, good to know others are interested in the XPL HI triple if I remove it. Iāll keep that in mind depending on whether a LH351D is offered soon.
I removed AR coating from both sides of one lens, and only one side of another. The latter was a prototype which apparently only got coated on one side.
AR coating increases the amount of light it lets through. Thatās what itās for. However, AR coating also tends to change the tint. So I sacrificed a few lumens for a slightly better tint.
For comparison, ZebraLight uses a button timing of ~600 ms, and even that is too fast for some people.
The fastest Iāve seen anyone use was ~256 ms.
Edit: it looks like ZLās āpress timeoutā is about ~600 ms, but their ārelease timeoutā appears to be more like 350 to 400 msā¦ almost identical to Andurilās default ā¦ side-by-side they appear to be exactly the same delay.
Gotcha. I just did a little āhead smackāā¦ because of course, āanti-reflectā means thereās no light lost on reflection. Iāve got the NW 3D tint. Itās beautifully neutral. Not seeing any green, yellow, or blue. And actually on lower modes it seems just a little warm to my eye. Iām very happy I went with it, over the much yellower 7A.
Count me in as one of those people who gets a little annoyed by how long I have to hold the switch from off on my ZL to keep it from going to turbo. And to hold it for off. I sure wish theyād adjust thatā¦ Overall, I think itās a terrific light, for itās own proprietary distinctiveness. Would be kind of cool to have Anduril running on it, though.
My timing was extremely low tech, a digital stopwatch. :person_facepalming: . Highly unscientific or accurate but it was the best I could do. My badā¦
. EDIT:
Yep, sure looks neutral white to me. It was pretty clearly stated in the product details page. And itās a good rendition of NW, too. Iām really happy with it. I donāt get how some people are all bugged out about all their lights being warm Hi CRI. Itās nice to have some varietyā¦ The thing to avoid is screechy ice blue. The nasty of 6500K LEDās past. Yuck.
Is there a way to reset the Anduril UI to factory defaults ?
For some uknown reason , double click (from OFF) doesnāt seem to enter Turbo , or other shortcuts (battcheck , lock out etc ) (edit: with triple/qud click etc) .
I have been using mine for a while now, and after the initial problems with dirt etc, everything has worked well. I am now using 35Eās instead of 30Qās as I donāt need scary bright for 10 seconds
I find I prefer the 7A to the 3D given the choice. I am liking this flashlight more and more and even used candle mode last night. I have also got a 219c on order and am definitely in for any copper versions in the future.
All in all its a very good flashlight that has taken over from my Emisar D4s (for now :-)) as my goto light.
Thanks very much for all the effort that has gone into this.
Received my 3D and 7A, both DOA. Followed troubleshooting but no luck reviving them. Havenāt given up yet but the chances seem like theyāre gettting slimmer.
Really wanted to try Anduril but doesnāt seem like a good trade off for reliability. Guess flashing the D4 is my next stop.
