FW3A Troubleshooting / FAQ
Should I write one for the assembly personal?
Yes you are right, from off i ramp all the way up till max and it shut itself off.
I just remember the head heats up dam fast and dam hot during the lightning storm mode.
In past designs, it was the other way around. Voltage would spike to levels way above the attiny’s accepted range, at the trailing edge of each FET pulse. The attiny13a was okay with this and kept working anyway, but tiny25/45/85 is more sensitive to staying within its specified range. That’s why the Astrolux S41 used a BLF-A6 driver instead of a Bistro driver.
It shouldn’t be an issue with anything recent though, so it’s kind of a long shot. This issue was fixed a long time ago in pretty much everyone’s driver designs.
That can probably be fixed by taking the light apart, cleaning everything, and putting it back together in the recommended order. Teacher’s FW3A thread has the details on that:
do you mean take apart the head and tailcap ?
Every once in a while , mine will ramp up then shut off. Usually just twisting the head cures it .
Okay, points to software.
:person_facepalming:
Okay, this points back to a physical problem. If it shuts off at high current, then you have a weak connection somewhere. It sounds like there is excessive resistance somewhere and low currents allow the light to work fine, but when the current ramps up the weak connection gets overloaded and the circuit breaks. Clean all threads, battery ends and spring ends. Make sure the driver retaining ring threads are both clean and tight.
BTW, you turned off in Lightning storm so lightning storm is the first thing that turns on. Lightning storm always starts with a quick blast of turbo. This is why going into the blinky modes causes the sudden turn off.
1. True
2. Are you sure about this? Based on the below… I think your statement is not correct Jason. Recheck yours please.
  • Mine do not always “start with a quick blast of turbo”. It is completely random…. from having to wait several seconds for anything to happen, to a full blast lightening strike, and/or anything in between.
Mine was doing that first thing this morning.
After fiddling for a while, including some time at turbo, the ramp up to off problem quit happening.
I thought I remembered ToyKeeper saying it always starts with a big blast of Turbo on some other thread. I tried it on my light ONCE, and it started with a big blast so I thought it was true. It does seem to fit the profile that Atoms light kept doing the same thing every time.
I just now tried it a few more times on my light and it does seem random. I’m wrong.
Since Neal was unresponsive to my email requesting info on a possible return, I decided to chance it and see if I could confirm what my multimeter was telling me. Both solder joints on the MCPCB were intact, but after desoldering the wires and removing the driver, I saw that the black wire had broken at the solder joint to the driver. My guess is someone installing the MCPCB or the retaining ring got a little too forceful. The 7A is back from the dead and has quickly kicked the 3D to the “for sale” pile.
Neal hasn’t replied to my original email from Saturday the 25th. I sent it to his Hotmail address listed on his site. I also sent a follow up email yesterday, the 27th when ToyKeeper suggested I reach out for a replacement. Is there an alternate method of contact available? I don’t have the knowledge, skills, and tools to try and fix mine.
I was hoping to have a light for when I go camping in June, next month.
2019?
Let me try to take it apart.
If this is directed at me, yes, June 2019. I have a camping trip toward the end of the month that I would love to take the FW3A with me.
Glad you fixed the 7A…. :beer:
PM me if you want to sell the 3D. :+1:
Just take it apart, clean it threads n’ all, reassemble in order… as ToyKeeper & Jason suggested.
Go HERE . Read it, do what is says step by step, and hopefully that will fix you up. :+1:
Your being optimistic. He is not going to read anything on the weekend. So from Monday to now is like 2 days. The reality is it may take a week or two to get a response. It varies based on how busy he is.
It looks like you weren’t on the interest list so you didn’t get the message with full purchase and support details… here’s the relevant part of the message:
We should probably also add this to the top of each FAQ thread.
That’s how mine behaves. It teases with a few flickers to attract the eyes, then WHAM!
