ahh yes tactical… but strobes gunna be a dead give away, can you imagine it, out side the cartell, everyone’s in position, shh….shhhhh? whats that noise? i mirrion candle power strobe mode…WITH RAMPING!!..
Some firmware projects have recommended fuse values inside the source file. However, for all of mine, check the bin/flash-tiny*-fuses.sh scripts in the code repository to see the most up-to-date recommended fuse values for each MCU.
Okay, I just updated a bunch of source files to remove any outdated fuse info from the .c file and replace it with a pointer to the flashing scripts. Those scripts are much more actively maintained, and more likely to be correct.
In the bin/flash-*-fuses.sh scripts in my firmware repository, it has recommended fuse values for each type of controller chip and usually a link to a calculator which shows what those values mean.
In most cases though, the fuses don’t need to be flashed. Sending a .hex file by itself is typically fine, and less risky.
Almost there. But it’s not under ToyKeeper/ , it’s under bin/ .
BTW, to compile the code for an arbitrary driver, you’ll probably need to edit the source a little bit to choose relevant settings. And the crescendo.c file also points to those same flashing scripts for info about the fuse values.
ToyKeeper, I just wanted to say a big THANK YOU! for all of your hard work creating these awesome flashlight interfaces for all of us flashlight fanatics to use—your work is very much appreciated!
Hum, I am note sure it that already exists Jon!
I believe it is a little bit like the Anduril for the Sofirn SP10S project (to be run on AAs and 14500s): it is still being “searched” the ideal formula to make those more “advanced” UIs on alkalines! :weary:
BTW, the light in which I have Crescendo currently is the On The Road i3 zoomie flashlight.
Keep in mind that Crescendo running on an attiny13a does not have memory; not enough space on the chip for all the code. The code written for an attiny25 has memory available.
I’ve flashed Crescendo onto a Texas Avenger-Driver and it doesn’t ever ramp down. Otherwise it behaves like it should, so a single tap ramps up, a triple tap goes to turbo, and so on. A double tap simply does nothing.
I’ve tried to change the code and make it go to Turbo to make sure it’s not a problem with the ramping down code, but the phenomenon persists.
I’m a bit stumped and can’t really tell if this is a hardware problem or if there’s something odd with the software after all - I don’t really get the code in all detail. How can I best go about debugging this?
What MCU is the version you flashed written for? And what MCU is in the driver? There is a version that is written for attiny13a and a different version that is for the attiny25. But I would think if the wrong version was flashed then there should have been an error. ??? I like that firmware.
