FW3A… atm.
Not the newest light, but to me the Emisar D4 is to be mentioned. Very compact, side switch, runs on 18650 or 18350, up to 4k lumen with XPL, large choice of emitters, great quality… plenty of reviews. You can’t go wrong with this one.
I have the D4 and the FW3A - they’re different, but both good. Neither are cheap in comparison to a Convoy, which I also have in several flavours. My two most used of those would be the M1, and the S2+ in both long and short.
For what it is worth, the D4 and the FW3A are both much of a muchness. I’m using the FW3A as my headlight right now, and it suits that purpose better than the D4 due to the tail switch. The D4 is better in the hand with the side switch, I think. With a 18350 tube the D4 becomes a pocket rocket as well, though it has to be twisted to off to avoid disaster.
In summing up, the FW3A would be my current choice for a desert island trip. Ramping UI and a tail-switch for pocket use would just edge out the D4.
None of these are my EDC though - that’s an i3S Olight Cheap and cheerful, but oh so reliable and useful.
D4S is my favourite.
I really like my FW3A and have been using it quite a lot. I like so much about it, even the HI leds. I wonder if I’ll even get one with hi cri when it comes available.
Who am I kidding? Of course I’ll get one! $30 is quite a bargain.
Mine currently is a custom 18350 S2+ in grey. triple 219b with Texas Avenger driver. a really, really nice light.
Right now, I would have to give a vote for my two, new E07s. They are perfect, yet don’t get mentioned as much as the Emisars, because of initial production quality issues. But that has all been solved, since March with their latest run. Unlike the Emisars, the E07 has an illuminated side switch, which is a must for me. The auxillaries are also a nice feature,missing in the D4 or the FW3A. Only a bit bigger than the FW3A, it gets amazing run times with a 21700 cell, not to mention all of the great emitter choices. I selected for one of my E07s, the Nichia 219B for a high CRI, while for my other, a Cree XPL Hi V3 3A, for maximum output of 6900lumens.
An honorable mention, must also be given to my D4S, which is comparable to the E07, with almost everything, except for lacking the illuminated side switch. It hosts a longer lasting 26650, making it a bit chunkier than the E07. However, it is a bit shorter
For me the Convoy S2+ is a staple flashlight. I carry one on-duty every day and it simply works. I have them mounted on several of my PCC (pistol caliber carbines) and shotguns as well.
For off-duty EDC however I carry either the Nitecore EA11 or EC11. They have all the functions that I like and use.
A Nitecore SRT3 for my vehicle. Again, has all the functions I find useful.
For me Zebra sc600w mk3 Hi. Perfect light.
Mike
I find this interesting because I found that I was quite unimpressed but that one. I got it and the Sofirm SP10 V2.0 at the same time and even though the Sofirm is much cheaper and not as bright, I find it to be a much nicer to use light.
FW3A for me
prior was Tool AA v2.0
prior was Fenix PD35-tac
I like all the suggestions. Thanks. I did order, and am waiting for delivery for the S2 XP-L HI. One of the reasons is because I could order the shorty body and use it with a 18650 or using the shorty body the 18350 which is actually my preferred size for an EDC. My current love affair is with the SolarForce L2M because it can also be used with a long body and a short body and using the L2T head that doesn’t have the hex section makes the whole short body very light and it has a 35MM head and reflector so I get more from the LED. And what is making it even better is now I can buy the triple LEDs and power them with a 18350. But I am very curious about the S2 so I’m anxious for it to arrive.
Emisar D4 v.2 with AUX lighting and 95 CRI LED choices.
Chris
FW3A
Enough folks have burned holes in their pockets (and other things) with the D4 to confirm that it is indeed the current HOT EDC.
Yeh mine got a bit hot ,started smoking & melted itself off,
Dbstar had his meltdown after a small drop,
Did you figure out the cause.
No , it’s dead ,I’m waiting on neal to sort it out ,he said he will send a new head a few weeks ago but no joy yet , he’s not responding to my emails anymore.
From what I hear, you’ll get it. Too bad we are starting to get failure reports. No common theme though. It would be a PITA to lock out the FW3A at the tail cap every time.
