reserved
reserved
Nice knurling (or should I say “knice knurling” / “nice nurling” ) on that M21A!
M21A shows (2) braided springs!
So those are the 21700 versions of L2 and C8+, right ?
Oh wow, very much interested in the L21
mostly yes
Ordered 2 x M21A
Thanks for the great price!
1 Ordered, thx.
I received an OUT OF STOCK notice from Banggood for the two M21A that I purchased.
Yes, that’s what I did.
Thanks
Ordered 1 m21a. Thank you Martin!
What would be the best 21700 battery for the m21a? And the best place to buy it?
I bought some purple Shockli 21700 4500mAh high drain, (received them today) i will let you know if it works ok with the L21a when i receive it
Thank you!
Very tempting! Any chance of including the M21A host?
Has anyone done a review on the m21a? Also, I’m curious to know what the throw is.
I’ll probably take an L21A later this month… But just to mod it to a white flat.
Ok, received the L21a today and the shockli cells do NOT fit the L21a !
Drat, now i have two brand new cells which do not fit and have no use for.
It seems the diameter of the cells is too large. With my caliper i measured the inner diameter of the tube which is 21,5 mm.
The shockli cells have a diameter of 21,7 mm.
Drat, now i have two brand new cells which do not fit and have no use for.It seems the diameter of the cells is too large. With my caliper i measured the inner diameter of the tube which is 21,5 mm.
Will it help if you remove the wrapping?
