Is your low mode on the e01 as low as e07? And are you able to program top of ramp to the maximum brightness?
[♛ FreemeGB] FireFlies E01 LUMINUS SST40W N5 5700K 2300lm Andúril 27100/18650 EDC Flashlight - ENDED
Any chance you can post some outdoor beamshots?
The low mode is nowhere near as low as the E07. I have not tried programming the ramp yet.
Received my E01s, thanks FF and Freeme
Initial impressions are good, i like the size/shape, beam pattern, brightness, switch lights, and it feels good in my hand, this is pretty much the 21700 light i’ve been waiting for. The silver has a plasticky feel to it though, even when compared to the black version, but i kinda like it.
Anduril seems to be missing features though, such as most of the blinkies and muggle mode. I recently read somewhere that TK was asked by FF to provide a stripped out version of Anduril for the E01 but FFs website states Anduril, and that it’s same Anduril as the ROT66, and the UI image on the ROT66 page indicates full Anduril with the all the blinkies and muggle mode, so i have e-mailed FF asking for clarification.
It’s definitely a cut down version. The other E01 thread gives a bit of information
Hello, I received my E01 today and love it as much as all my other FF lights!
I immediately flashed it to real anduril as it’s what I know and use on over a dozen other e-switch lights however I was wondering if the original source code and/or HEX file was available?
I can see it being very useful for loaner lights or lights I give away and potentially as a smaller size starting point for me to add to later.
I’m still on the fence with this light. I just wish it had turbo in the mode sequence. I’m debating selling both of mine e01.
Why not flash them to real anduril?
I received mine today, so far I like the flashlight, I am annoyed that the purchased 21700 battery that I ordered with the light has the positive terminal crushed, did anyone else get their flashlight battery like that? Is there any fit issues with this light or did I just get a used battery instead of a new one?
Same here.
Has anyone measured the dimensions of the TIR lens? Diameter and height?
Looks like Fireflies made the same mistake with too short battery tubes again? (see E07)
Can you guys please check if there's a too big solder blob on the driver spring? This could also lead to crushed terminals.
Yes there is a big solder Blob on the driver spring
Also Lishen batteries are too long and may have weak top for all we know.
You said you received the light today in previous post so I’m wondering why you asking for dimension?
I already found the answer 30 x 17 mm why do I want to know you ask? To see what other optic / reflector options are available to try.
Just reviewing one now, 2500 lumens @turn on. Tint is excellent. #5700club
Recieved my E01.
I did not get a pocket clip with it. I written an email to FF-lights but no answer yet.
I will flash normal Andúril on it. Oterwise I like it!
Did you order one? It’s not included as default, it’s a $1 add-on you have to choose at the time of ordering.
