Yes, those boards for the XQ-E should work. The Cube and the XQ-E have nearly identical footprints, essentially like a zero ohm SMD jumper almost. Pretty easy to get solder paste on and reflow because of no separate thermal pad in the middle.
Are those boards running those emitters in parallel? Do you have to address each emitter individually or can you run them all off of one set of positive and negative leads? The second board should fit in something like a Convoy M1/M2/S11, but would need an XP-E size centering ring for the optics to fit properly. You can still get by without the ring. The first board would work in any of those hosts, but would need a spacer for the compact TIR optics to fit. Those boards are unfortunately a little too big to squeeze into an S2+ shorty.
For a 12 volt light you would need 4 of the Luminus Cubes in series. That second board Talley-Ho linked, if that came in a 4 series setup, that could be a candidate for your host. You would need to make sure the width of the MCPCB would fit.
Manufacturer specificication sheets for forward drive voltage and compatible footprints. Website specifications for MCPCB size; footprint compatibility; and operation type, like 4 series, 2 series operation and so on. Confirming those two pieces of information match will give us our compatibility. Sometimes, we can bend the rules a bit and use something like a 3030 footprint LED on a 3535 footprint. That information is gained from experience.
I ended up using a Convoy S3, so I could easily play around with different optics.
thanks for the info. did a bunch of reading and I think i understand everything you wrote. did you ever stumble upon any other mcpcbs were compatible with the luminus cube?
I have modded a lantern with 2000K LEDs, its basically a “Kerosene lamp yellow flame on low” tint. A very, very warm yellowish glow, but i like it for night lights & moon light modes. I bought a lot of 2000K flame-yellow cheap LEDs from Ebay for that purpose, (the 1W Luxeon bead-type LEDs.
I don’t have this on hand and was wondering the same. The jumper pads seem to be made to run LEDs in series and there is none for another configuration so it probably needs 3x sets of positive and negative leads.
The other board I was looking at was this. Since the thermal pad is electrically isolated it might work with the quad setup technique mentioned above a bit better. I’ve worked with those MCPCB’s, and they are difficult to solder. You would need a hot iron to get it to work.
This would be a better candidate, however. You would need to make sure its 20mm diameter fits in the light you want. It is configurable for 12 volt or 4 series operation, so it should electrically work in the light you mentioned earlier, but I don’t know if the diameter would fit. That is where you would need to measure the board that is in there already.
How could 6000K have high CRI, wouldn’t that be too blue, and not render reds/oranges accurately? Chromatic adaptation is the mechanism that in the human eye that corrects for CCT/SPD differences.
“Chromatic adaptation is the human visual system’s ability to adjust to changes in illumination in order to preserve the appearance of object colors. It is responsible for the stable appearance of object colors despite the wide variation of light which might be reflected from an object and observed by our eyes…An object may be viewed under various conditions. For example, it may be illuminated by sunlight, the light of a fire, or a harsh electric light. In all of these situations, human vision perceives that the object has the same color: an apple always appears red, whether viewed at night or during the day (unless it is green). On the other hand, a camera with no adjustment for light may register the apple as having varying color. This feature of the visual system is called chromatic adaptation, or color constancy; when the correction occurs in a camera it is referred to as white balance.”
So the human vision equivalent of white balance is known as Color Constancy. I learned something new! Not the best source, but it’ll get the job done in this case.
Most typical households use 2700K light bulbs. Incadescent light bulbs from yesteryears are 2400K and 100CRI. Candle flame is 1800k and 100 CRI. If you use an E21A 2000K 9080 in the day time, it will look too yellow and not like it like my own experience when I first received my Tiara Pro 2000k from Virence.com. A few months later, I used it at night when my eyes are adapted to the darkness and warmth, and the color rendering is amazing. It didn’t look overly yellow at all and good thing is it doesn’t wake up sleeping family members like my other flashlights do on low output because it contains almost no blue wavelength.
Also if you test a 4000k light at night when your eyes are adapted to 2700k or 3000k ceiling fixtures, it actually looks slightly bluish. It’s all about your eyes adjusting to the color temperature.
Yeah the wizard pro mcpcb is 16mm. I’ll have to wait til Virence gets it back in stock as it seems like the best option for that particular light. I was chatting with him and another 16mm board is ready to be sent off for production but he has some large projects currently is very busy at the moment. But I think I’ll still want to play with the luminus cube 1800K in a different host.
“The CRI is determined by the light source’s spectrum. An incandescent lamp has a continuous spectrum, a fluorescent lamp has a discrete line spectrum; the incandescent lamp has the higher CRI.”
so how can any led have decent CRI?
since its ‘white light’ is basically just blue and yellow, no red and no continuous spectrum?
i;m trying to learn here, not just being difficult…
Your eyes take at least 45 minutes to adapt. What is the color temperature of your indoor lighting? Are you looking at 3000k daytime, under 5000k ceiling lighting, or WW ceiling lighting?
wle, to add onto this, are you looking at a computer/smartphone/tablet/TV without blue blocking filters as well? Do you have an LED street light or high powered security light outside any of your windows?
Also, I don’t know if you’re using fluorescent, but most household LED products are at least one nominal CCT higher then advertised. So verifying that those LEDs are 3500K and not 3800K, would be helpful but not likely possible in determining what light is actually around you. That verification can only be done with a pricey spectrometer, unfortunately.
Nope, see here the spectral power distribution of the Nichia 219B in the FW3A (red line compared to the black line which is the reference light source), it is not just made out of blue and yellow wavelengths.
See also this Maukka’s test here, for the Nichia Optisolis 5000K for example.
On the middle upper graph, see how the optisolis 5000K (in red) is close to the reference light’s CQS, hence its excellent CRI ratings.
