One of my gripes with Lii-500 was too closely spaced out slots. From the pictures, it looks like this Lii-500S seems to have a bit more room, so that’s a welcome change.
I’m guessing the current display is just the selected current and not actual current, just like the old model?
Anyway, I mainly use my Lii-500 for discharge capacity tests, and this Lii-500S does not offer any improvements there, so I’ll skip it. I do like the new display though.
I have no interest in pressing buttons to see Individual read outs plus the 500mAh MAX discharge. $15 more for another Opus from my hometown dealer is well worth it to me! As usual it is ALL about “Individual” preference.
FINAL POST on this thread! Several “may” be happy!
I know the Opus cost more which usually correlates to more features.
I DOCUMENT my capacity results for future use/tests, both on Microsoft word[written] and photos for Comparison and degradation analysis!
I could NOT do what the picture below illustrates w/ the Liitokala lii- 500S, XTAR Dragon and many others, That is,seeing information at the SAME time for ALL four slots.
I use the 300mA setting for very old NiMH AA cells. Anything faster than that, and their high internal resistance causes the charge to terminate early.
I also use it for AAA NiMH cells (though 500mA would probably do fine), and for 14500 lithum-ion (though again, 500mA is probably fine).
It’s too bad they dropped the 300mA charge setting. I like the 2000mA addition, but I’d rather have 300mA for my low-capacity cells.
I lied. ,about last post. Had to comment on the video!
Staring at 3:59 mark She could NOT get the 26650 Liitokala to make contact w/ positive tab in slot 2. So she used a rubber band which did not work either! :laughing: lol!
That has happened to me[no contact on positive end] w/ a few of my 26650 on certain chargers,Neodymium magnets solve that problem.
I should NOT have said last post!!! My bad,Forgive me,It is my 59th Birthday[Last year in my 50’s! ]today,a beautiful day, not a cloud in the sky and was 47F when I got up,going up to 70F :+1:
Freedom of choice is Great isn’t it? The price is right for the Liitokala,WHY one would prefer to press ALL those buttons for info is beyond me,I guess they have more time than me and are not interested in documenting the results in a simple manner[One Photo]
I GREATLY prefer looking at ALL the info at once which I already explained in post # 24! Also it charges EVERY battery[except very old ones] to 4.20V and is relatively accurate in comparison to HKJ’s results,average about 3% higher.
I TOTALLY prefer the Opus for reasons stated and many more!!! lol!
Yeah… to me pushing a button is pretty easy. Since I log the results one at a time anyway… I much prefer reading & seeing the results for each bay separately. It cuts down on confusion for me.
’My Opus’ is less accurate than my LII 500’s. Others may or may not find this to be so with theirs.
So who is the judge as to which one is more accurate?? Let us NOT forget that ALL of these chargers can show slight inconsistency from Charger to charger.That goes for Liitokala and Opus and whatever,none are exactly the same.
I had *KING OPUS that was consistently within 3% of HKJ and Numerous times LESS than 1% difference and several times less than 0.1% from HKJ,It is all in the Opus threads on here and CPF.*PRINCE Opus is what I have had for 2 years now. It RARELY is more than 3% higher than HKJ,Good enough for me and to each his own.
Lets NOT FORGET that besides the button pushing, the Liitokala will take TWICE as long to discharge! [500mah VS 1000mAh for Opus] 90% plus of my batteries are 18650 and 26650
I already know what teacher is going to say!! His Liitokala is more accurate than his Opus!….Maybe so, he did not have King or Prince Opus!!!
Agreed, but I’ve also found that going too slow causes problems with failed Delta-V termination, at least on my BC-700. 300mAh is useful, whereas 200mAh is often too slow to ever terminate even on very old NiMH AAA’s. A balance must be found between premature and delayed termination.
300mAh is a requirement for NiMH AAA’s, in my opinion. 500mA seems too fast unless the cells are nearly new. After all, that’s over 0.6C for a new 800mAh cell and even more for a worn one.
I suspect that few people that own these chargers use them for NiMH batteries, however. I still have a large collection of NiMH, but I suspect that people coming into battery-powered hobbies in the last decade have focused on Li-ion exclusively.
The Lii-500 doesn’t fully top off NiMH cells according to HKJ’s tests and my old BC-700 charger has more appropriate rates for that chemistry, so I use the Liitokala for Li-ion and the La Crosse for NiMH.
Yes, I doubt the charger is using -dV to terminate my old NiMH cells. But they do eventually terminate, after putting about 2x more energy in them than they have in capacity. I suspect the charger must also terminate at some fixed voltage, if it doesn’t detect a -dV signal.
I do sometimes just remove the cells when I see the voltage has risen to about 1.55v. Since they old and worn-out anyway, I don’t really care if I’m damaging them by overcharging. I just like the fact that the old Li-500 charger has a 300mA setting so I can actually charge them.
I really do like the display on this model but I have a ton of charges that fill this niche. Maybe I will pick one up later when they put them on sale without the power supply at the $15 to $16 range. I mean I like the display but I’m not going to look at it very long anyway. Great buy for those whom need a good charger though. I would buy it if I needed it.
