Same here.
30mm x 18mm SMO Aluminum Reflector
Same here.
Has anyone measured the dimensions of the TIR lens? Diameter and height?
Looks like Fireflies made the same mistake with too short battery tubes again? (see E07)
Can you guys please check if there's a too big solder blob on the driver spring? This could also lead to crushed terminals.
Yes there is a big solder Blob on the driver spring
Also Lishen batteries are too long and may have weak top for all we know.
You said you received the light today in previous post so I’m wondering why you asking for dimension?
I already found the answer 30 x 17 mm why do I want to know you ask? To see what other optic / reflector options are available to try.
Just reviewing one now, 2500 lumens @turn on. Tint is excellent. #5700club
Recieved my E01.
I did not get a pocket clip with it. I written an email to FF-lights but no answer yet.
I will flash normal Andúril on it. Oterwise I like it!
Did you order one? It’s not included as default, it’s a $1 add-on you have to choose at the time of ordering.
No. I thought it is part of light. They make a huge gap and it is not containing as stock? It looks bad with that gap for no reason. I better not get a lanyard but get a clip. I have a box with full of lanyards. And you can use any lanyard but that clip is special for this light…
Mine came in today with a clip, so I checked my order and I did have to specifically add a clip for $1.00 which irritates me as I only use it for anti-roll
I ordered the light with the battery,but never recieved them.Emailed them already and still no answer.I recieved the package on the 4th june.Is anybody have the same problem before with ff?
btw,what include in the package?i ordered mine without the clip.I got the flashlight itself,lanyard,spare o-rings,18650 to 21700 adapter and thats it.
That’s it other than the clip
I like this light, but was kind of expecting something with more throw, Maybe I am spoiled with my modified lights…! If I find a reflector I wonder if it would be more throwy than the optic…
I found a couple reflectors on Kaidomain which should work:
30mm x 18mm OP Aluminum Reflector
I’d like to try some alternative TIR optics as well, but can’t find any to fit. The Carclo 30mm optics are only 14mm tall. Anyone know where FF sourced the stock optic?
Easiest way would be a different led. Sst-40 is 4mm2.
FWIW I expected more flood and was surprised (but not disappointed) at how much throw it had for the led / optic setup!
http://kaidomain.com/S026177-30mm-x-18mm-smo-Aluminum-Reflector
http://kaidomain.com/S026178-30mm-x-18mm-OP-Aluminum-Reflector
I saw those, but I think the reflector base might short with the MCPCB contacts.
