2000k flashlight
147 posts / 0 new
staticx57
Last seen: 3 hours 31 min ago
cetary
Last seen: 2 hours 26 min ago
That has been my observations when comparing the 1800K Cube to my 2000K E21A. The E21A looks positively like a regular incandescent lamp in comparison. I also have an SST-10 deep red, and my chromatic adaptation kicks into overdrive and even 2700K looks like midday “daylight”.
Could we get the tint closer to the BBL while keeping CCT low though? I see a surplus of light at 620nm, but that’s near red light. Maybe a minus red filter? I was thinking the usual Lee Minus Green. I’m guessing for the mix you used the 2200K/1800K Cubes?
djozz
djozz's picture
Last seen: 3 hours 17 sec ago
According to the datasheet the Cube has a massive chromaticity shift when warmed up, the 1800K version starts like in the chart above but at 85 degC (operating temperature in light fixtures) it drops down right on top of the BBL.
So we need bad heatsinking, something for a P60 drop-in? Smile
staticx57
I did forget about this phenomenon, I do remember reading this in the datasheet. I did take these when the emitters were cool. Actually thinking about this, I can try again when they get warmer but the setup I am using is designed to make sure they do not get 85°C or even that warm to the touch.
cetary
That might change the CRI/R9 values as well? Would make it a quirky emitter if the R9 got better the harder/hotter it was pushed.
xenotar80
https://www.mouser.com/ProductDetail/Cree-Inc/MLBAWT-A1-0000-000UEA?qs=%...
would this be able to replace LEDs like the SST20 or 219B or 219C? Standard 3535 LEDs? And would it work well?
Can’t find very many warm options for 3535 LEDs.
HONDARIDER
HONDARIDER's picture
Just ordered some 2700K XP-L HI’s from Mountain Electronics. I’ve used 3000 and 3500k before quite a bit but never a 2700. Probably not a drastic difference.
xenotar80
I really do want something 2200K and under. But I also did get some SST20 2700K from kaidomain! Going to give that a try and see how they turn out. Probably in an acebeam headlamp
cetary
You can go for the 2200K Cree XT-E or or the 2500K Osram Oslon SSL-180 for 3535 drop installed. They don’t have the best appearence though, 80 CRI only. My 2700K XP-L HI turned out to be closer to 3000K in the SMO Convoy C8.
I’ve ordered the FW3A copper, and will be sticking some 2700K SST-20’s in it, can’t wait.
xenotar80
I’ve ordered the copper FW3A copper, and will be sticking some 2700K SST-20’s in it, can’t wait.
nice! just ordered fw3a too and will put the sst20 2700K in it too. seems like that’s the lowest cct and highest CRI option we have for a 3535 footprint
cetary
Pretty much. My example of the 2500K Osram Oslon had a higher CCT then the 2700K SST-20 95 CRI as did the 2200K XT-E.
xenotar80
Have you tried dedoming the sst20 2700K? that might make it warmer maybe?
Tally-ho
Tally-ho's picture
Last seen: 8 hours 13 min ago
When Clemence will be less busy with his city light project, he will make a triple MCPCB for Nichia E21A (lowest CCT 2000K but R9050)
SKV89
Last seen: 54 min 11 sec ago
The E21A 2000k has been verified many times to be 9080
xenotar80
fw3a with E21A would be amazing. can’t wait.
xenotar80
yeah i think maukka measured the e21a 2000K with an R9 of 98
Geuzzz
Geuzzz's picture
Last seen: 3 hours 2 min ago
You could try the Lee zircon amber filters to get even lower cct.
http://www.leefilters.com/lighting/zircon.html#zircon-warm-amber
djozz
djozz's picture
The measurent was in the hotspot on high setting. The Mi1C does have a AR-coated lens that may have affected tint a bit.
SKV89
Djozz which emitter did you measure?
xenotar80
djozz wrote:
p=.
i’m assuming that’s an E21A in 2000K. looks like it to me. what flashlight and mcpcb is that?
djozz
djozz's picture
I did not know that I posted a quiz Smile
The light is a Klarus Mi1C in copper, the led an E21A 2000K R9050, bought from Clemence. But it behaves like a R9080.
cetary
People are on about “look at how candle-like this 3000K XP-L HI is” with their Anduril lights, but the Copper FW3A, Anduril Candle Mode, and finally candle colored 2000K LEDs…yes the actual copper candle. Cool Not to bash on Djozz
Agro
Agro's picture
Last seen: 3 hours 40 min ago
Samsung offers LM302Z+ mid power LED with CCT down to 1800K. CRI80 only.
Not that it’s some great option but that’s an option. Clemence sells compatible MCPCBs.
Agro
Agro's picture
Another 2000K option:
Nichia NF2W757GT-V3F1 is another 2000K CRI80.
samyy
Last seen: 12 hours 14 min ago
Just discovered on AE this
Ok, it looks like cheap chinese no-name LED. But what do you guys think? Does it deserve an attention?
Agro
Agro's picture
I stumbled upon 1800K Luxeon Z ES:
https://www.aliexpress.com/item/32921772540.html
Note that according to Lumileds datasheet such warm CCT is not available. So it may be a fake LED – but possibly still not a bad one. Especially considering that there’s little competition in that warm end of the high-power LED market.
Sari33
Last seen: 11 hours 24 min ago
It’s a good sign if people ask quality very warmer lights.
because market lacks,untill there is low demand.
But it’s important not going on Infrared ahah
xevious
xevious's picture
Last seen: 19 hours 21 min ago
Not sure why you’d want a light throwing 2000k…
But have you considered filters?
SKV89
I would never get any leds under 2700k that are not hi cri and does not have a high R9 value. At this level of warmness, color rendering will look like amber light or high pressure sodium light. You can’t really make out the colors. With an ultra high CRI LED like the E21A 2000k, I can still clearly make out all the colors. In fact, when my eyes are adapted to the color temp, everything just looks real good with the E21A and I don’t even notice the yellowness anymore.
flightless22
flightless22's picture
Last seen: 4 hours 2 min ago
Yes, dedomimg SST20 will make it warmer. Somebody did this with SST20 4000k
