I’m not sure what constitutes “bad” when it comes to knurling. It’s grippy so in that respect it’s good and does its job but when it comes to the body tube, like you say, it’s so shallow it just feels like sand paper and I dont think brass or ti or copper will really be able to shine cause it’s not got any smooth parts on most of the light.
I sure hope they keep it low-high. There was a poll either here or on Candlepower about low-high versus high-low, and it was a landslide in favor of low-high.
I’ve never seen clear anodization IRL but I’d try it. I’d honestly prefer some good ’ol fashioned color anodization, preferably in hunter/forest green. That color is sadly neglected in a lot of releases. Pink or purple would be great for the ladies in my life.
Now that I’ve played around with the raw aluminum version in low-high, I’m impressed. Operation is wonderfully simple. The two modes are nicely spaced. The low is very usable and lasts a long time. The high is very bright and reaches out well for a light this size. The tint and color rendition are excellent. The only thing keeping it off my keychain is that I don’t like the feel of the raw aluminum. I’m really excited about seeing anodized versions in low-high.
Ok I felt bad for poopoo’ing on the knurling without offering better feedback. Here’s a few minutes on a belt grinder. The mid section is clean looking and smooth now and I left the head as is for better grip. IMO, this feels and looks much better to me.
Anyone tried this with 10440 li-ion cells? Besides Noctiluco, that is.
Noctiluco said, in a related Sofirn C01S 4000K 100 lúmenes thread at ForoLinternas, the torch becomes a lot brighter and works fine with li-ion. But he only tested the thing with protected Turdfire cells, this is the reason I am asking for further feedback. Does the C01S implements low voltage warning or cut-off for 10440s?
I have one C01S that I used for crash-testing, works fine but looks crap now. I will try one of the new Vapcell 10440 cells in it (seems more high drain even than the Efest 10440) and see what happens :smiling_imp:
Be wary of the low voltage cut-off thing, set a li-ion charger at hand djozz.
I wonder how does the thing work with higher voltage cells. “DD” with sense resistor limiter like in cheap SK98s? Did someone dissected its driver yet?
I have no idea, but since I started this hobby, the many cheap AA and AAA flashlights that i had either burned with a li-ion, or work well but never work again in boost modus, or keep working fine with either cells. I do not think the typical boost driver for AA and AAA cells are specifically designed to function with Li-ion cells but it is simply a side-effect of the circuitry.
So the 10440 gave surprisingly a lower output than an Eneloop. It appeared that both the tail spring had collapsed, breaking contact, and that the driver stopped working as boost driver: lengthening the spring made the 10440 work again but not the Eneloop. One component on the driver, on the left, showed a tell-taling bulge:
Note that there’s no easily identifyable boost coil.
Inductors (coils) come in chip-style packages that look very much like a SMD capacitor. I’m not so sure what those two components are towards the bottom: the reddish thing and the sparkly looking one. One of those might be the inductor. Granted, there are coil-less ways to boost voltage (eg, charge-pump) but I doubt that’s what we’re looking at.
Wellp, the red thing seems to be a 47µF tantalum capacitor. Thus, the grey/silver finish sparkly looking thing must be the (tiny!) inductor.
If that is the driver inside current C01S flashlights, how can Noctiluco say his C01S works good on 10440 li-ion cells? May someone give an explanation?
Could it be because he is using protected Turdfire 10440s? :-D
Sorry to read that djozz :zipper_mouth_face: I was thinking it could survive but…not :zipper_mouth_face: So only Ni-MH and alkalines on this one! And it will do the job for sure
