That flashlight looks almost exactly like the Sofirn SD02A (uses XPL-HD 3000K tint)…
Any chance of a runtime test for this one?
Sofirn has an XHP35 version as well, with a different body design that isn’t dive level submersible. LINK. A good bit cheaper at $24.
Btw, it seems interest in that Wurkkos WK20S model caused price to spike from $39.95 to $49.95.
This is an interesting diving light: 10W-XM-L2-Diving-Flashlight. Very prominent carry-handle. It’s XM-L2, putting out 960lm, but has a proprietary battery pack serving 5400mAh with water tight charging port. LED indicator for battery level.
Yeh, I mentioned that up-top. Seems to be all-in-the-family. :laughing:
The Wurkkos arrived in today’s mail. It looks and feels good. The switch action feels really interesting. The beam certainly is more warm, sort of orange-yellow, than my yellowy Eagtac GX25A3 (3700K). But actually not quite as warm as the Adventure Sport Super Bulb XM-L2 S6 dropin in my 4D Maglite, even though the latter is supposed to be 3000K also. I look forward to seeing it at night.
First thing I noticed, though, was that the tailcap ridges aren’t pronounced enough to satisfy me; the light could still roll off a flat surface if bumped. Happily a Streamlight 75701 anti-roll ring fits and is now adorning the business end like a king’s crown.
The Streamlight Siege I’d been waiting for came in the same mail batch today, too. This is shaping up to be a great weekend!
Hey! The 2000lm NW ’20S is on sale for 34bux, and the 1000lm WW ’20 is reduced to 26bux.
https://www.amazon.com/gp/product/B07Q21MXLG/
I like the brightness of the ’20S, but the WW goodness of the ’20 can’t be beat.
And I added a write-up for the WK20S in the OP as well. See above.
Wanted to get some comparative beamshots (’20/’20S) against some trees but the neighbor’s got his spotlights on all night for the past two weeks, muddying up everything.
I’ve found that my muscle memory expects a light to turn off with a brief click, but since this light only advances the output mode by that means (off is via long press), it’s mildly irritating. Otherwise I like it. It tailstands more steadily than I thought it would just from looking at it.
Considering all the lights I have that need a click, press’n’hold, double-click, half-click, long-click, etc., it’s no big deal for me to adjust. Each one has its own “personality”.
Thank you, Lightbringer! You’re the best scout we have for interesting new lights that otherwise might be off the radar. The Wurkkos WK30 and WK20 are both terrific little lights. The WK20 is notable especially for the 3000K CCT, the nice 1 lumen low-low level, and the magnetic switch (which is much less vulnerable to grit than, for example, the ring on the Sofirn SD05).
I have mixed feelings about the WK20S. For underwater, I like the higher output. But, for out of the water use, it’s unfortunate Wurkkos eliminated the low-low level. And then there is the tint. Back in post #8, Lightbringer, you worried about the potential “urine-yellow corona” of the XP35. Well, that’s what my copy has. Reading the description too quickly, I thought the emitter was an XHP35 HI, but it is actually the XHP35 HD, which is notorius for its tint shift: in my case, a neutral white hot spot, yellow corona, and purplish spill. Is yours better? Diffusion film could probably help, but I don’t want to lose any throw.
I plan to use both the WK20 and WK20S on a freediving trip to Catalina Island in September, and I will report back on how the lights performed underwater, and whether the tint problems of the WK20S were noticeable in actual use.
Absolutely. I reviewed one ’20 and bought another ’20 just because of the CT/tint and it being a great little light.
I didn’t even think about the grit factor, though. If I knew how the rings came off the ’20 and ’05, maybe I could figure out a way to prevent ingress (eg, slap on some waterproof grease to “pack” the gap).
Yeah, mine has that, too. A lot of flip-chips have that problem (and some non-flip-chips, too). I imagine that underwater and backscattering, it’d be less of a problem (built-in diffusion film, so to speak). When white-wall hunting, yeah, it’s very noticeable.
It’s funny you mention diffusion film, though. I slapped a sticky piece (“frost”, I think) on the ’05 to get rid of the corona, and it’s an incredible — and I mean incredible — indoor floodlight. I love my Cometa for indoor lighting, like going down the basement and not bothering to flick on the lights, etc., and it’s a wonderfully even blanket of light… within the lit circle. A bit harsh as things come into and go out of view. But the ’20S with its hella bright beam and diffusion film, it’s a similar wall of light, but with much softer edges. Like an area light, hella bright, but not like a stage-light with harsh edges to the beam.
Even the WW ’20 looks incredible with DF on the front glass. Moonlight/Lowest is incredible for close-in viewing like just checking the clock or whatnot.
Kewl, sounds good! I’d think it wouldn’t be a problem, much less so in murkier water (again, acting as its own “diffusion film”), but that’s only a guess. I’m thinking you’ll be impressed, too. :laughing:
Oh, check out Markus’s review of the ’05, too.
Kewl, tnx!
My only underwater experience with flashlights would be testing them in a utility sink. :laughing:
It’s a division of labor, Lightbringer. If you scout out any dive lights, I’ll buy ’em and take ’em in the water. Thanks for being our weather eye for interesting new lights.
No worries. One of my favorite playthings for a while was the DV-S9.
It’s CW, so you’d probably like it. Sharp design, love the magnetic slider (removes easily for cleaning if you unscrew the colored collar, but is “polarised” so be sure you put it back in the same direction), takes a 26650 for lots of oomf, and has O-rings out the wazoo.
Oh, and any issue with all these lights is parasitic drain, a good 10mA or so, or running down a cell in 3wks or thereabout. So tailcap-lockout is a must when storing them.
What’s the LED used on the WK20S?
I’m presuming it may be a clone of the SD05 (uses XHP50.2), although in the form factor of the SD02A (uses XPL-HD 3000k) = which would be the same as the WK20, my guess.
THANK YOU ,Great sharing, new offers, 50% code, please contact me if you are interested.
WK20 50% CODE
WK20S 50% CODE
Half off? Noice…
I KNEW I’d buy one of these WK20S’s some day soon.
Just bought on Amazon US… using the code happily provided by Mr. Shao- THANK YOU SIR!
I HAVE the Sofirn SD-2 (and love it) so this should be a close “cousin” with more output. My wife and I WILL dive this light (and the new SD-5 I got last month) around X-mas time IF I can get to Cozumel with Covid and all.
