Wait, pure silver wire?
That’s expensive.
And does it pose the same problem as a copper wire bypass?
That’s expensive.
Well it isn’t gold! (mine is in leaf form - not convenient at conducting).
Have a few odds and ends in the shop. Had some platinum once - used it as a heater.
As for the copper coils, they do get compressed. What did you imply by “lower and lower” ?
Besides, my rudimentary set-up for tailcap measurement gave 17 amps with the stock XPL-2 and Q30s in the lamp. I may try out your springs to see the gain.
My idea is the copper is the primary conductor, the nickel steel spring to sustain the mechanical load.
Visually, the tailcap looks very much as I had made some year ago.
I could take it apart and compare to my original posting, but I rather wait til I have your gen 3 springs as I may try them.
The trick may lay in the soldered cap, this retains the copper coil. These coils were just wound around some mandrel, I believe some 5 turns and had the ends loop flat. The caps were presoldered and the nickel steel spring was fluxed with an acid (something laying in my soldering pastes drawer). The base is completely puddled in solder. A very good mechanical connection.
Some have posted 20 and some amps on a Q8 (to be taken with a grain of salt). But with my phone’s lux meter and a conversion factor that I derived from a known flashlight, I got some 5700 lumens (on turn on). I’m happy with the results.
Anybody can still enter the BeCu spring GB BTW.
It’s not nearly done yet.
People can still enter for the best spring design yet.
We are at:
571 Large BeCu Silver+Copper plated springs
507 small BeCu Silver+Copper plated springs
That’s pretty much what I meant.
Copper doesn’t need to hold the strength on its own, when they are joined together at the top and at the bottom steel should push it up.
And no, double BeCu won’t be nearly as conductive as that.
1 mm copper wire (AWG18) has 50% better conductivity than 0.8 + 1 mm BeCu (w/out extra coating). Furthermore removing coils should reduce the conductor length. And…without tight coils I think that conductor could be thicker.
OK guys.
I’m going to ask the manufacturer if this is actually a good idea or not, and we’ll see what they say.
I already know the answer, but might as well ask someone which perhaps has more practical experience than us.
If they say it’s good, then I’ll just not order the large spring, and use this steel+copper spring array.
If not, well…
Just seems like you guys are getting closer and closer to something like this:
We are at:
596 large BeCu springs
532 small BeCu springs
We are at:
621 large BeCu springs
557 small BeCu springs
Preliminary specifications:
Spring upper diameter: 6,25mm
Spring base diameter: 9mm
Spring thickness: 1,0mm
Spring height: 12mm
Total number of coils: 5
Plating: Copper(25um) + Silver electroplating
Small spring:
Spring upper diameter: 4,25mm
Spring base diameter: 5,70mm
Spring thickness: 0,8mm
Spring height: 10,5mm
Plating: Copper(20um)+ Silver electroplating
We are at:
Source: https://giphy.com/gifs/southparkgifs-3o6Zt4gdNsj11l7Eje
Just had an hypoglycemia, saw BlueSwordM's location and T & P came out in my mind. Fully naive joke. O:)
Out of topic again if you don't mind, but now that I'm in let me say I also find this pretty funny:
Source: https://www.mallorcadiario.com/supremacismo-blanco-no-piadosos-nazarenos
The Semana Santa is just a religious tradition, but certain foreigners seem to look at it in a different way.
Mmmkay, enough with the off topic.
I would like 70 large springs and 30 small springs.
Added to the list.
We are at:
696 large BeCu springs
592 small BeCu springs
So, we’ve got some confirmation for the final specs.
Large spring:
Material: Beryllium Copper C17530 38% IACS
Spring upper diameter: 6,50mm
Spring height: 12mm
Small spring:
Spring upper diameter: 4,35mm
Spring base diameter: 5,80mm
Will probably be ordering the springs soon.
Just post your interest here, and I’ll get you on the list as quickly as possible.
If needed, PM for large quantities of spring orders so we can discuss more about it.
I would like 10 large and and 10 smalls. Are these doable for a beginner?
Yes, that’s the nice thing.
They are extremely easy to solder to.
That’s one of the main driving points of using these.
Added to the list:
We are at 706 large springs, and 602 small springs.
Have you received the funds I sent you? I’ve never bought from you before and want to be sure you got it, payment message was my username, check the pm.
Yes of course.
I put usernames+private names in an encrypted folder when I receive the payments.
I’m just waiting for the LEDs to ship now, as there have been delays regarding this.
Sucks compared rather than ordering from Mouser, but tint bin trumps everything.
In other news…
Sign me up please for:
1 large + 2 small for my Manker BLF A6 (will those work?)
1 large + 2 small for my Manker BLF X6 (will those work?)
1 large + 1 small for my Lumintop GT Mini (will those work?)
4 large + 4 small for my Lumintop BLF Q8
4 large + 4 small for my Sofirn BLF LT1
8 large + 8 small for my Lumintop BLF GT
Total: 19 large + 21 small 3rd Gen BeCu springs please :D
:BEER:
- SAM -
