Thank you so much for the tests! This seems to be a decent boost driver in this light. I am waiting to see how the Astrolux MF01 Mini turns out, then I’ll decide. This looks like a good light for extended walks at night.
This might relate to the last few posts, but I noticed that after using this flashlight for a bit anytime I try to use turbo it immediately steps down…is this because the battery is below 3.8 volts?
Hi all. I have a simple question. If with Mhvast ts70 let’s say from MID i double click and go to turbo if i click once will it go back to MID or turn of the light. And if i longpress from turbo will it go low mid high or do something else.
1. Mid > Double Tap > Turbo > Tap Mid > Tap > Off
2. Mid > Double Tap > Turbo > Long Press > Mid > Continue Pressing (button isn't held off) > High > Ultra High > Low > (Mode cycling)
Hi. I have one question about the regulation of the output after 3.8V in wih you have measured 5.06A what in lumen is that i gues somewhere about 3000lm or i am in mistake.
