Wow nice build! You make the spacer?
Super nice!
I am contemplating a similar build with the M21A.
Beam shots??
Stunning!
You give me idea for my unused zippo :+1:
Is that a switch (the cylinder shaped stuff)?
Iām thinking about using reed (magnetic) switch for my future build.
Yes .
Yes, but only for myself, itās just a hobby ā¦
Iām not going to make money on it.
Yes it has three switches, you can see it working in the linked thread :+1:
Switch PCB is modded back to 2P battery. In the past i removed the copper layer on 60% of the switch side. So i had to fix it. Used a 0,1mm copper sheet, soldert 2 layers together and glued it on the pcb with thermal glue. Then i were able to install the new switch and the new metal button. Needed a spacer to make it work nicely. But i did not have the right material on hand. So i had to make one brass spacer 2mm and one copper 0,5mm. Soldert both together and made it fit to the aluminium Tailcap. Now i am waiting for some GITD powder to fill the space arround the metal switch button. And the new pill from Kirill that seems to be stuck in customs. But untill then i will remove the red marked area on the pics to make the tube more flat on both sides.
Put some magnets on the Sofirn C01ās I have. Bought here (Convoy Store):
Used a drop of super glue to fix the magnets in the lights!
https://www.aliexpress.com/item/D5-3-magnet-for-18650-flat-head-battery/1590874652.html?spm=a2g0s.9042311.0.0.3da24c4dkz3qek
Rebel Lime in a Convoy C8+ on a LD25 3A driver. I wanted to use one of my old D80. But the 17mm driver was not a good fit. Even with almost empty battery the rebel lime is pulling the full 3A. It is still not 100% centered. But it is looking fine as it is now.
Soā¦ what is Rebel Lime good for? I mean, is it an aesthetic choice, or is there a practical purpose?
To put out a lot of lime colored light :sunglasses: Kidding! I really have no special use for it. But i find it more interesting to work with a led i never used.
And i like the green/lime colored leds. So i had to get at least one Rebel Lime. To bad that the MCPCB is a Aluminium board and not a Copper DTP
Waiting for new boards from Neven to complete a few more color light mods.
I have a load of (20mm) Rebel Sinkpads doing nothing, I can send you some if you like.
With the rebel does the star have to be a little off center to properly center the dome of the LED?
Reminds me of my Quarks and Jetbeamsā¦ :smiling_imp:
Tint is almost as bad as some white CREEs
āalmostā
Rebel Lime... For a second I thought it was a joke for how the oldgood XPG2s look with a wavien collar and FET.
It's, uh, a color of LED I've only witnessed within the bands of the Cree Fried Egg.
djozz
Thanks! But i have one Rebel Lime and one Rebel Alu Sinkpad left here.
I never thought that it would be such a pain to center this led. Even when the dome is right in the center you get a beamprofile that looks not centered. Only thing that helped was to tilt the reflector a tiny bit. This way you get a good looking hotspot. But still some artifacts arround the hotspot.
Next led i want to build a light with is the KP CSLNM1 F1. The Led4Power 6A driver is ordered (will turn it down to ~5A) and i can not wait to see how it looks in the D80 or the Cometa.
But i am really interested in a deep red led with high output.
Has anyone had trouble with blowing an SST-40? Iāve been messing with TIR lenses in an 18350 S2+ and it lasted about 3 seconds on the highest level. I was using a FET driver but thought I would be OK without a bypassed spring and the Efest 18350. Regardless of mode the led will only come on as if itās in a moonlight mode.
I thought Astrolux was using a FET in one of their SST-40 lights? Maybe I just got a bad one?
