You could get some dupont connectors and put them between the programmer and the SOIC ribbon cable. this would allow you to reconfigure however you need. You may even be able to replace the ribbon on the SOIC with the dupont connectors.
Alternatively, if you have some solid core wire of the right diameter, you could use that instead of purchasing the dupont connectors.
If you can get the ribbon off the SOIC without breaking it, you could reattach the ribbon in the correct configuration (maybe solder it?).
Probably took too thick wires for the aux LED on prtototype
on first assebly I had the driver twisted to align to the heads cutout and ripped the pad where the optical nerve was off
so disassemble again, looks messy with the heat paste all around
Prototype, got a small bug, but can be used without the LVP chip, the bridge pads were designed on it so no big deal
but the fab let me down not cutting out the 20mm boards from the panel, so I got ordered new ones
Also made a quick thermal test, that thing gets hot fast
if you flash driver and remove the optical nerve resistor you can solder there the Aux supply
then flash a firmware variant that supports the Aux LED option
Removed 2 7135’s from my FW3A. It still thermal throttles with a full battery. But with a more empty cell it can sustain max regulated output for a long time (probably indefinitely). I did a calculation to determine how much the efficiency actually went up, and it wasn’t much… But still technically more efficient than the pwm equivalent with 8 drivers.
I was worried that the mode spacing (or ramp rate) would be non linear between the 1x7135 and 6x7135 sections, but it’s still very good.
