FW3A mod thread. Post yours!
Awesome I do have those Dupont con doctors. I bought them when I got the usbasp not knowing why I needed them but now I see where they come in handy :slight_smile:
Modded with high CRI LH351Ds
Probably took too thick wires for the aux LED on prtototype
on first assebly I had the driver twisted to align to the heads cutout and ripped the pad where the optical nerve was off
so disassemble again, looks messy with the heat paste all around
Prototype, got a small bug, but can be used without the LVP chip, the bridge pads were designed on it so no big deal
but the fab let me down not cutting out the 20mm boards from the panel, so I got ordered new ones
Also made a quick thermal test, that thing gets hot fast
Will the aux board work with the stock mcpcb or only the noctogun?
both
Nice Lexel! When will they be available? Would be interested in solid colors like Ice Blue, Red and Orange….
Looks great, Lexel! I assume the aux LEDs would always be on?
if you flash driver and remove the optical nerve resistor you can solder there the Aux supply
then flash a firmware variant that supports the Aux LED option
Looks really good Lexel
Uh ? What is that ?
Also, I might be interested in an Aux LED board for my FW3A :smiley:
Skynet.
Removed 2 7135’s from my FW3A. It still thermal throttles with a full battery. But with a more empty cell it can sustain max regulated output for a long time (probably indefinitely). I did a calculation to determine how much the efficiency actually went up, and it wasn’t much… But still technically more efficient than the pwm equivalent with 8 drivers.
I was worried that the mode spacing (or ramp rate) would be non linear between the 1x7135 and 6x7135 sections, but it’s still very good.
last night my Glow washer from @CRX came in! unfortunately my pics aren’t uploading but I’m sure you folks have a pretty good idea of how it looks :smiley:
I’m drooling over here Lexel. :smiley: Nice work! How soon can we expect these to be ready?
Does anybody know of a diffuser to fit the FW3A?
as the fab screwed me up once I hope in 2-3 weeks
Nope… :wink:
Thanks!
25mm… I think there may be a few diffusers from other manufacturers that could fit. One that comes to mind is by Nitecore, with a 25.4 mm diameter. One could line the collar of the diffuser with some aluminum tape to get a snug fit.
Did anyone try making a diffuser that is water/liquid filled?
This is what I ordered. I will see how close it fits, but the aluminum tape is a great idea!
