This one:
https://www.gearbest.com/pocket-knives-folding-knives/pp_009780560071.html
Waiting was a smart move RC, it will be worth it.
Okay, looks a bit like the Ganzo FH41 (except for the shape of the blade):
https://www.gearbest.com/no-lock-folding-knives/pp_009505043020.html
Unfortunately, Gearbest has increased their prices of FH21, FH41 and FH51 quite a bit.
On a side note: Interesting when you look at the link I posted in this post. It says "no lock" even though it uses a liner lock. :FACEPALM:
That is interesting Lux-Perpetua. I clicked your link & scrolled down, under “Specifications” it said “Liner Lock”; which of course is correct.
Strange indeed…. …
Specification
General
Brand: GANZO
Type: Folding
Lock Type: Liner Lock
Blade Edge Type: Fine
Blade Length Range: 5cm-10cm
Weight Range: 101g-200g
OK 2+ months later My second batch of 10$ Go Commas arrived ...
Much better lock -up on three of them and one has about a 25% lock up ...where as the first one has about 15% One is about 85% the other two are 75%
Big damn difference .
I'm also wondering when people said the angle on lock ups are normally about 7 degrees .
My guess on these is they are at a much steeper angle than 7 degrees...(see ..I've been sharpening knives lately and know what 12 degrees looks like ) :)
At over 2 months I was really questioning if they were ever going to arrive.
I still like the look /shape /feel/weight of the knife... and at 75-85% I'm much more comfortable than I was with the first knife I received .
Wow, ordered my Gocomma Quick Open ($9.99) from GearBest on 06/18/19, got shipping notice on 06/19/19. I guess we'll see how long it actually takes.
I got a Ganzo Firebird FH41 the other day and I gotta say… it quickly became the favorite of the FH Series knives I have. That being the FH11, FH21, and now the FH41.
The Fit n’ Finish, blade sharpness, etc., etc. is all up to par… just like on the others. But the blade shape & grind do it for me.
Drop point blade is 88 mm / 3.465 in. , flat ground from edge to spine.
The G-10 slab handles are a simple & straight forward design…. no weird shapes or finger grooves (which I hate btw . ).
Blade length is a bit long for my preference, BUT…. the overall design & feel of the knife overcomes “my preference”. I love it.
It opens to a firm lockup with a flip of the flipper tab.
I see it is $28 as I write this. I got mine for $23.14 a few weeks ago. If it drops in price again, I’ll be forced to get a spare. . .
Ganzo Firebird FH41
I really like the FH 41 also. I like it’s straightforward clean lines and it reminds me of the Massdrop Keen folder (which is a bit pricey).
That's a really good looking knife . I looked at that one for a long time/ read reviews /watched videos ...arugh!!
Yeah, I have the FH11 and like it.
I have the FH21 & like it even more.
But for me, the FH41 takes it to another level. I really like it!!
Good video Boaz… I can relate. . It never ends though it seems.
Uhh… all this talk of FH41 makes me want to get one, even though I am perfectly happy with the FH21 already.
My Gocomma knife (that one here: https://www.gearbest.com/pocket-knives-folding-knives/pp_009152095568.html) just arrived. So far, I'm quite impressed by the quick and easy flipping mechanism. It works great for the price. However, my liner lock looks the same as on the picture of the page before, i.e. it's coverage is about 40% according to what I could see with my eyes. If I got you guys right this is not much of a problem, right? Unlike my Ganzo knives the blade of the Gocomma knife comes not very sharp from factory. A quick test with a sheet of paper revealed that the blade gets more or less stuck when cutting through it. So, this one needs to be resharpened.
(picture below is not mine but taken as reference from the page before)
New Gocomma knife...
I call it the Gocomma Coffee.
https://www.gearbest.com/with-lock-folding-knives/pp_009490641435.html
It's supposed to "quick open" like some of the other Gocomma knives.
Looks cute.
Teacher.
You may like those plain straight sided knife body’s.
OK for pocket toy and cleaning nails.
But be careful if you ever use them for any decent knife work.
Where you have to hold firmly while pushing or stabbing.
Especially when/if they have water, oil, grease. Anything wet on them.
It’s very easy to slice your fingers as it slides up out of your grip.
That’s the reason “professional” knives usually have grip grooves
or very pronounced dimples in scales. and finger grooves.
GRIP is the most important item on a knife apart from steel and edge.
Yrs ago we had flat slab wooden scales on Commercial fish/butchers knives.
Any old Trawlerman you see will have lots of slices on his fingers.
We had to gut and Gill all the fish b4 packing in the ice kits.
We used to saw/cut slots, dips in the scales for better grip.
Keeps your finger tendons longer.
“”“If disassembled, can’t that piece be gently bent a little more to provide more coverage?”“”.
Lightbringer.
Bending the lock bar probably wouldn’t make much difference. in the space avail.
Also Change the agle of contact faces.
Be better to strip knife. Put that side of frame in vice.
and file/ diamond plate a tiny amount off that face.
Keeping the angleof face the same.
Front/back. AND Side to side. There are 2 angles involved.
That would allow the lock face to travel over a little more for more face contact.
WHile still giving full contact pressure.
And allowing the full contact to still occur with age, as they wear.
They are cut so as the moving part WILL move over further to take up any wear.
We just speeding up the “wear” a little.
More wear. More move over. MORE contact face. Better all round.
Would also allow any slight adjustment IF faces not truly flush,
Just be careful. Smaller IS better…
Practice on a 20yr old throwaway first.
Just got a Civivi Baklash, if you want an outstanding flipper knife, this is knife is the S#%$
I can find 0 faults with this thing, perfect fit & finish, dead centering, solid lockup, hair shaving sharp and incredible action opening and closing, even comes with a nice case and micro fiber cloth, I don’t have a gocomma but I’d bet this guy can kick the crap out of one lol.
I would hope so!
It costs several times as much as a Gocomma.
it’s worth it tho, I put off getting one for a long time, but these are hard to beat for the price.
