Put seven of these into a bigger host and things get interesting!
There used to be a BLF development fund. We may try to restart it though we would need to make sure it doesn’t end up the way the previous did.
I believe such assurance is possible to make…
We only need to maintain a pair of trusted BLFers holding the keys.
When one disappears, the other changes the keys and shares them with one another.
2 is a number large enough to reasonably rule out simultaneous disappearance yet small enough to to reasonbly believe the trust won’t be breached.
As to technical issues - there are many handheld lasers available. The laser community figured them out.
I believe we can learn from them….and while I still don’t have any idea of how to cool them down I believe it’s possible to do it well enough.
Actually I have a hunch that “well enough” is significantly more than 50 °C.
This stuff is pretty exciting. You say it's like 2000s LEDs, so I think about what LEP will do in 15 years.
I get that the stuff is big money. The automobile industry (for headlights) is obvious, but so many applications would love efficient lux. If you can start replacing short-arcs in any application, there's reasons to pay for it. Smaller size, decreased power, increased longevity, decreased complexity...
I can't wait until Enderman gets his hands on one.
Read that NDA very carefully before you confirm or deny…
Yes correct, the datasheet that was sent to me had a different first picture but the rest is the same.
I think the most imporatnt thing here is how this one behaves in subzero temperatures, my experience with lazers and subzero temps isnt good
Hey, I already have one of this, but, can’t talk about it, sry
But seriously, this sounds interesting.
I had several damaged lazer genetics( the big ones) and i played a while with those for a month or so but sub zero temps are a pain…and combined with a heavy recoil: voila, problems
Yet, i ve found a nichia green lazer that works but the price became terrible
Once I tried to repair ND30, that thing is PITA…
That's a teaser, not a real datasheet. All the important info (thermal, emission angle diagram etc., solder footprint, isolated thermal pad?) is missing.
…hence the nda I guess. But if the expectation is that it will eventually be sold for 50 dollar, that is another reason to not buy a sample and just wait for things to happen
Did you know that Lasercomponents resell these or that they sell the Albalux white fibre coupled laser? https://www.lasercomponents.com/fileadmin/user_upload/home/Datasheets/sld-laser/laserlight-smd.pdf
https://www.lasercomponents.com/uk/product/albalux-fiber-coupled-module/
Nice article about this technology by Nakamura (SLD is his company) https://www.bloomberg.com/news/articles/2019-01-15/the-headlight-of-the-future-is-a-laser
I did some searching on what do Laser pointer people do to keep their diodes cool.
I’m only scratching the surface but what I’ve seen so far looks unimpressive:
Get a huge host with lots of copper inside. If the diode is still too powerful, don’t run it continuously.
And they typically run less powerful diodes.
F.e. this is a highly rated host that can handle 3.5W (actually 7W at 50% duty cycle):
Note that the SLD LEP runs 14.3W…
See, the problem with most laser pointers is that the heat dissapation design is absolute crap.
Not only is the thermal design of the pointers themselves bad, but the way laser diodes are manufactured, thermal resistance is quite high.
I still wonder why laser manufacturers haven’t standardized themselves on a standard 3030/3535 footprint.
I guess the reason for not doing this is not to make it easy for the public to acquire stupid powerful lasers.
BlueSwordM, I’d love to see you elaborating more about it…
Could you please clarify whether you think that the one I linked (Sanwu) is among the crap ones? It seemed well regarded…And so I assumed it was one of the best ones. And therefore used it as a sizing gauge. Actually…the size is not far from from my expectations.
Could you please also tell more about the design problems that you mention?
The one you showed above looks like a showpiece to me. Lots of material everywhere so heatsinking should be good anyway but I can imagine that more careful designing it will result in a body much more lightweight with just as good heat shedding.
Maybe the laser guys are less into continuous use than we, and short bursts can be solved by heatsink mass, while real heatshedding while keeping the laser unit under 50 degrees is a huge challenge?
But what do I know of lasers? :party:
I've kind of avoided taking the dive into lasers because I have this nagging feeling I'd either burn down my house, go blind, or both.
@Djozz and Agro, I would advise you to see how a laser light is usually built by looking at styropyro’s video:
Most laser lights don’t use thermal paste to aid in heat transfer, there are no direct thermal paths for the lasers diodes to dissipate the heat effectively, most laser modules are press fit into the casings with no solder or thermal paste to aid in thermal transfer. Finally, most laser heatsinks aren’t directly connected to the hosts.
That means while the light itself doesn’t get very hot, the laser diode does.
How do I know this?
Well, I have friends that really like high power lasers, and since they know I’m quite knowledgeable about lights, they came to me when they had problems with them.
Anyway, I opened up many laser lights, even custom ones, and man, I was so disappointing with the crappy heat paths that the lights provided, and worse, how the laser diodes themselves are heatsinked.
Even something like a Convoy C8 is built way better in terms of thermal path vs most diode laser lights.
And the thermal design of SMD 3535-5050-7070 LEDs with thermal pads are leagues ahead of almost all diode lasers.
TLDR: Our lights, and LEDs+MCPCBs, are very well designed to get the heat away from the LED as quickly as possible.
Laser diode lights and the diodes themselves, on the other hand, are designed pretty badly in terms of getting the heat away from the laser diode, meaning laser diode lifespan is much lower than conventional LEDs.
