The output of level 1/150 is almost entirely dependent on the hardware itself. It changes with emitter type, battery voltage, and a fair amount of per-light randomness. The range is generally about 0.05 to 0.30 lm though.
Gotta love that per-light randomness. :slight_smile:
The D4 and FW3A also both only use 1x7135 for the moonlight.
However, the per light randomness is not entirely random. One known factor is that some 7135 chips do not work well if both the PWM frequency is high and the duty cycle is low.
The FW3A was requested specifically to use a known good 7135. As far as I understand it (a lot of this information is scattered across numerous threads that predate my time here, so I may be partially mistaken), Richard has not been able to consistently source those chips, so he tweaks the firmware on drivers he sells like the Moonlight special to match what the chips he gets can manage as their lowest stable output.
Sooooooooooooo, where can I order a programming clip for my precious? I’m not opposed to making one, but I’m getting lazy in my advanced age. I did try searching and found people mentioning ‘just order one’, but I couldn’t find where.
Also, should we start a list for TK’s special edition? I know I want a couple of purples. Someone tossed out 100 as a number to be made. I highly doubt that will be enough. My worry is that I’m on a trip where I only have internet every few days at best for another 3 weeks. If they come up and sell out before I can order one, I’m going to be seriously bummed.
I got my standard SOIC8 clip off Aliexpress, was only 2 or 3 bucks. There are different clips out there- mine is black. Have seen blue ones as well. Also check what cables you would like or need.
Easiest way of hooking up are Dupont cables F-F.
This clip should work for any standard ATTINY mcu
You want a USBASP adapter, and a SOIC/SOIC8 clip - I bought mine all from AliExpress, but you can get them all over the place:
Happy to help with how it wires up; there’s threads on it but I’m on mobile atm; slow to find.
https://imgur.com/a/4u0eRV0
Quick photos of my clip and USBASP.
Must be something wrong with my eyes.
I know it’s poorly lit and not on a good camera; was just trying to get a quick image done :slight_smile:
More pics of the blue and orange hands free device!
that is a great picture, especially the PIN1 sticker. I should also do something like that.
If you have a Raspberry Pi, avrdude is really convenient to use on raspbian (not that other OSs would be difficult).
eBay/AliExpress for something like “6 arm helping hands” - got it a looong time ago now. I think it’s more for RC drones/copters, but having 6 arms is brilliant for holding everything down when working on it.
Wow, thanks! That helps a lot.
There are also some differences in firmware. Most moonlight-special drivers run something Bistro-like on tiny25 or tiny13, and they run moon mode at 13 to 17 kHz. This makes the code smaller and simpler, which is good… but it’s also extra-sensitive to changes in the underlying hardware. What’s bright on one light may not light up at all on another.
I did it differently in Anduril though. It underclocks the MCU at low modes, so moon runs at 4 kHz instead of 16 kHz. With each pulse being 4X as long, it varies far less with different hardware, different battery voltages, and different LED types. The slower speed would be annoying at higher brightness levels, but down at moon mode it’s not really visible or audible. And as a bonus, it also makes moon mode use a fraction as much power, so it can run at that level for about 3X as long.
So… less finicky about hardware changes and uses less power, but requires more complicated code.
In addition to the answers given already, there are also relevant links in the firmware repository’s “README” file. :slight_smile:
Ok, so nothing to configure. Just is what it is. Was hoping to go a little lower. They seem brighter than that compared to a bunch of other moonlight lights I have.
0.3 lumens is definitely on the bright side for a good moonlight mode. However, I don’t find mine that bright, maybe 0.15 or 0.2 at most. I have the XPL HI 7A version, so perhaps that makes some difference. It’s still a little bright for my preference, but it’s usable.
Mine has just arrived, and it’s also the 7A. I’m surprised by the moonlight, it’s on par with my SC64w HI. The switch, on the other hand, too soft… the weak spot of the flashlight. But so far I like it overall!
That’s awesome for moon modes Toy keeper. Always amazing!
Luckily, mine came with Carclo lens.
