Great way to keep the hobby alive. First go for cool white high output -> replace everything with neutral white -> get into cri and replace everything again -> go on a 4000k hcri quest -> repeat for 3000k.
It depends on the specific light, but yes, on this one, the 1x7135 level is 65/150.
These levels are typically determined by a combination of measurement, math, intuitive feel, and rounding. So it’s different per light and I’d generally recommend looking up the details from the source code when in doubt. It typically has the exact numbers and the command or formula used to calculate the ramp.
Order placed June 20-
Emisar D4V2 high power LED flashlight
Color - Dark Grey
Led & Tint - Neutral White - XP-L HI V2 5D, 4000K
Please choose - one extra SS bezel (aluminum bezel by default)
Please choose - 18500 tube
Please choose - Magnet in the tailcap (No magnet in the tailcap by default)
Not shipped yet.
I already have a D4S with Nichia 219CT 90CRI, 5000K, and I like the light, but it gets real hot, crazy fast, so I decided to go with the Cree LED this time.
Received these washers and they fit around the D4 switch perfectly. The plain of the washer is even with the top of the switch rubber. Does not hinder operation of the switch but adds enough protection to stop accidental activations in your pocket. An added bonus is that it also works well on the FW3A and looks like it came stock . I use E6800 glue to attach mine. Does not harm the finish, holds well yet can be removed .
