Beamshots? Specs?
when its done ;)
Really David against Goliath
1 sold.
I want one in neutral white. Waiting commences…
Updates?
so these are an evolution of the GT/GT70…
25k lumens… how many lux, how much throw?
I had my GT70 de-domed to mitigate some of the loss of throw when I sold the GT…
i hope to get news and specs soon
Has the gt4 made it’s way to vob?
Specs:
- Lumens, its going going to damn bright
- heat management, WTF fins.
- weight, better hit the gym.
- price, who cares!
- beam pattern, see Star Trek photon beam.
so this is going to be $350?
will the head fit on the GT body?
I have 2 GT, 1 I use, and the other still in the box, could be cost effective to just buy thr head driver to update the GT into a GT4?
I would assume even if it worked you shouldn’t do it cause this tube will have to be designed to carry a lot more current. IIRC TA already melted some carriers.
So… Any word yet regarding performance of this monster?
I need to know the specs on this light ASAP before I buy an Acebeam K75… it’s one or the other… 6500 lumens /2500 meters for the K75, or whatever this GT4 can pump out… do we even know the dimensions yet? Yes, we know it’s comparable to the GT, but is the space for reflectors diameter actually larger/deeper? Or is it just more outer find for heat sink?
Please provide some update soon! Many of us are waiting to buy our next high output thrower… many other options coming out between the R90TS, Acebeam X65 mini, K75, Mateminco offerings, etc… with only enough money for one!
What about weight, my GT compared to my extended tube MF01S is much heavier?
Will this run at 100% full power on 4x18650 in a shorty tube configuration?
It’s direct drive, so there is no 100%. The driver does not have an upper power limit (in theory). So yes, it will run full power on 4 cells.
Of course, 8 cells will make full power a bit brighter.
12 cells, brighter still. It’s direct drive, so feed it more voltage and the brighter it will get. With 4 xhp70.2 it might do 25,000 lumen.
The leds forward voltage will influence the output.
With the MT09R, it had 3 x 70.2 and 4 x 18650. Output varied from 15,000 lumen to 20,000 lumen depending on the leds used. The GT4 will use 4 x 70.2, so output will be higher. Then add 4 more cells and output should go up higher still.
Thanks for the excellent explanation!
So I guess this light is similar to the Acebeam X45, with bigger reflectors?
