If so, yes, that is what I did
I flipped the silicon cap and the nubbin is now touching the metal cap.
I found out that, at least on mine, the curve (dome) on the silicon cap needed to be pushed down to make pressure more evenly to avoid noise due to a single pressure point.
After trying several “normal” silicon buttons, with and without the original below them, it was that solution what helped.
Later I may try to take a photo if needed, as I don’t have the FW3A with me atm!
Hum, I guess I didn’t noticed it much before, then!
I started messing up with the switch/caps, and thought it was because of that (and I guess it happened for a while, as the metal “activator” on the switch seemed to recover slowlyer), but it is a “feature”, not an error of my light!
Thanks for clarifying!
So, I arrived home and made some experiences.
Here’s the first video with the normal configuration of the FW3A in the tailcap:
Here’s the video with the inverted silicone cap, and nubbin towards the metal cap, as mentioned above.
And this was the last thing i’ve done to make it a “silent-stealth-tactical-decent” switch
with the help of these
I applied some white Scotch tape (adhesive) in the edges of the metal cap to avoid the metal “scratch” after clicking or pressing&hold. And inverted/flipped the silicon cap + nubbin
It is silent now! :innocent:
The bezel was made to ideally accept a Convoy S21a reflector. Currently I’m using the same S2+ SMO, which is too small and looks silly. Also, I ran out of time machining the part and didn’t get a chamfer on the outer edge. I made this of 7075 in hopes that it’ll stand up to drops better than 6061. Lastly, I’m going to dip the new part in an NaOH bath to try and match the surface finish of the rest of the light that was stripped.
If anyone has any suggestions to reflectors or single optics in the 22-23mm range and very shallow (10-12mm) let me know please. I’m hoping Simon makes available the S21a reflectors like he does with most models but as of yet haven’t heard back
Call me crazy but I actually like it a bit longer. Maybe it’s just because I have larger hands, but it feels a lot better now and that 5-6mm extra is unnoticeable in my pocket.
Diameter however is another story. You notice every millimeter there. I like the girth of the FW3A in hand (seems just right), but in the pocket it could stand to loose a mm or two.
