you know we produce DC power supply and USB tester, and today I want to share DPH5005 with you, unlike DPS series, the output voltage can be higher than the input voltage,so that it is called buck-boost power supply.
here is the technical parameter:
Input voltage range: 6.00-50.00V
Output voltage range: 0V-50.00V
Output current: 0-5.000A
Output power range: 0-250W
Product Weight: about 222g
Display module size: 79*43*41(mm) (L*W*H)
Open size: 71mm*39mm
Power module size: 93*71*41(mm) (L*W*H)
Length of connecting line: 200mm
Fixed hole center distance: 86mm, 64mm
Output voltage resolution: 0.01V
Output current resolution: 0.001A
Output Voltage accuracy: ± (0.5% + 3 digits)
Output Current accuracy: ± (0.5% + 5 digits)
Max allowable input current: 10A
Output ripple: 100mVpp
if you want to see more information,you can click this URL:https://www.aliexpress.com/item/32840324731.html
and of course it is recommended as other models
[Excellent fully functional device. Everything is super!!!
Made a case of a carbolite connecting box, a fan of 40x40x20 12 v 0,6 w paralleled from the fan on the board. The vent on the board consumes 120ma, the vent on the body of 10 ma. Together work
perfectly almost noiselessly.]
good stuff
NAME:RD UM34C Type-C DC Voltmeter ammeter voltage current meter
LINK: https://www.aliexpress.com/item/32880908871.html?storeId=923042&spm=2114.12010612.8148356.1.301b157bSAUGb8
review:
Those from Ruideng are crazy people =))) crazy people with crazy products =))) I saw this product on a video on bigclivedotcom youtube channel, I liked it, I searched it and I buyed it. Nice products with a ton of features. Very fast shipping and delivery. I really recommend the products and the seller.
REVIEW CONTENT:
【Good quality product. Collected, checked, had to screen the wires, there were interference with the display on the screen. Without problems connected to the laptop and smartphone. I advise you to buy!】
REVIEW CONTENT:
[Received today a parcel in pavlodar. Got in record 18 days. The speed of delivery was pleasantly surprised, but here the foam container was something crumpled in the center. Thought it was all, ppc. Broke everything. At the autopsy, it turned out that fears are in vain. The controller board itself is visually not affected. Dimensions live, amaze with minimalism. I haven’t checked yet. In absentia to the seller and the store 5… ]
REVIEW CONTENT:Very nice to work. I would recommend it to those who work with electronics. You have a professional power supply at an affordable price. Excellent. Thanks Rui deng store …
REVIEW CONTENT:All as always at the highest level at five plus. Thank you very much to the seller, this is not the first purchase in this store, i recommend the seller as a reliable, sends the goods quickly and quality packaging.
First, I will say that RD Tech makes great products.
However, these sales threads are very confusing and I have never been able to actually get the price that is posted in these threads.
It is usually either limited or restricted (new users only) coupon availability or the deal has expired.
Why not just simply offer a discount code for BLF members?
Hi friend
thank you for your message and your support
I don’t know the detail, most sale promotion have time limit, when the time is end, you can’t get the discount, please tell me which products you need, I can offer you discount
Hi my dear BLF friend
Thank you for your long time support in BLF , I saw many many people like our products and also need better price , so in order to appreciate BLF friends help and stratify some friends wish, I decide to release coupons for some hot sale products, and each week will update new coupons, hope you can find some big surprise
new share
Product name: RD DPH5005 Buck-boost converter Constant Voltage current Programmable digital control Power Supply color LCD voltmeter 50V 5A
Product link: 43.0€ 23% OFF|RD DPH5005 Buck boost converter Konstante Spannung strom Programmierbare digital control Netzteil farbe LCD multimeter 50V 5A|lcd digital voltmeter|voltmeter 50vvoltmeter lcd - AliExpress
[This power supply is the best of available modular units. Packed in a box of foam. The module itself is additionally in a package of foam polyethylene. All the components of the seller carefully packed in separate bags of puffy film. The assembly of the unit is simple and understandable. The board is made of quality components, the components are soldered smoothly and do not cause complaints, the flux is well washed. Also there is a bluetooth adapter, to connect to a computer. The unit has an active cooling system of the radiator, which turns on at a current of 10 amps. The accuracy of the voltmeter readings is very high, the error is only about 0,02 volts. Very satisfied with the product, i recommend to buy. The seller very quickly sent the goods and deserved 5 stars.]
new share
Product name:RD UM24 UM24C APP USB 2.0 LCD Display Voltmeter ammeter battery charge voltage current meter multimeter cable measure Tester
Product link:
[I recommend the seller in 100% very fast shipping, reliably packed, very good contact with the seller, the highest quality goods as shown in the pictures. My rating is 5+ thanks to the seller. ]
new share
Product name:RD UM34 UM34C for APP USB 3.0 Type-C DC Voltmeter ammeter voltage current meter battery charge measure cable resistance Tester
Product link:https://www.aliexpress.com/item/32880908871.html
[’S Days to Germany, looks great and works well. I recommend]
new share:
RD TC66/TC66C Type-C voltmeter ammeter 2 way multimeter
[This tester i received on free for my first satisfied delivery reactive days 12 to ufa everything works fine. When delivered, the packaging was damaged but the tester itself did not suffer a reliable packaging. Sold well done 5 + to him.] https://www.aliexpress.com/item/32968303350.html
new share
RD AT35 5 digits voltmeter ammeter multimeter
[Fast shipping. Shipping 16 days. Track tracked. Packaging is reliable. The product is quality and corresponds to the description! I ’ve known this store for a long time. All products purchased from this seller work without fail! And this time everything is wonderful! Thank you very much to the seller! Product and seller recommend!] https://www.aliexpress.com/item/33022448123.html
New Share
RD AT34 USB 3.0 voltmeter ammeter multimeter
[Excellent tester, the description corresponds, the device is packed reliably, although in football play. everything works. delivery to rostov on don 14 days. the seller thanks and good luck in business! i recommend of course) ] https://www.aliexpress.com/item/32897200670.html
new share
RD DPS5015 DC Step-down Power Supply
[Order received, everything is fine, came quickly and securely packed. The module works as expected. Excellent product, reliable supplier. Thank you.] https://www.aliexpress.com/item/32702714880.html
