Science Fiction Flashlights
thanks Snakebite thats it exactly :+1:
I may need a few more IQ points to fully grasp the explanation tho :smiley:
Interesting tidbit on speckle patterns (interesting if your into firearms accessories), it’s the mechanism used to create the reticle inside an eotech [or any other real] holographic weapons sight.
Just thinking about this topic.
Hank wanted us to be creative…right?
Here is an idea, a light with a wider variety of types(or spectrum) of light, that worked along with improved/aided human vision (like with Gordi Lafarge’s visor in Star Trek Next Gen)., so that humans could see a wider spectrum (or different types) of light. Sort of the way some night vision already works. Much of the technology already exists.
“All tools,” said Nessus. He pointed. “These are flashlight-lasers with variable beams. At night one can see great distances with these, for one can narrow the beam indefinitely by turning this ring. Indeed, one must be careful not to burn holes in nearby objects or persons, for the beam can be made perfectly parallel and extremely intense.”
Ringworld; Larry Niven 1970
^ 1970! :sunglasses:
probably just some weird thing your eye does
Okay, hank, you want science fiction, I can give you science fiction.
What say you of a torch that illuminates things and immediately scans and identifies the objects or beings it is illuminating and sending the info to display in that trusty personal digital device you’re bound to have (PDA, tablet, smartphone, datacube, whatever you want to call it)? All that with just the emitter, no camera needed.
Speaking of which, it makes me wonder what you’d get if you put a modern LED light inside SCP-914 and set it to Fine or Very Fine.
I enjoyed reading this thread though.
I know its a lack luster flashlight but the fact it was so bad made the game better, the flashlight in Metro was a great tension builder.
You had to keep whipping out a home made charging apparatus to make it work. And we complain about turbo only lasting 30 seconds, image your flashlight going off whilst fighting a mutant in the future in a Russian sewer.
I think the beam looks like a dusty Convoy C8 on an el-cheapo ultra mega fire cell :wink:
At least it’s not as bad as the NVGs’ battery life and the charger is silent :smiley:
how about a SF anti-flashlight?
it “shines dark” which makes
everything else appear “light”.
Flashlights will be obsolete when infared cornea implants become the norm.
Any infrared viewer still needs an illuminator; it would be nice to have corneas with “light intensification”, then the light of the moon, of the sun stars, without illuminator is enough.
Personally I would go with echolocation.
google :
The tapetum lucidum is a biologic reflector system that is a common feature in the eyes of vertebrates. It normally functions to provide the light-sensitive retinal cells with a second opportunity for photon-photoreceptor stimulation, thereby enhancing visual sensitivity at low light levels…
The tapetum lucidum is a reflective surface that causes the eyes of animals to look like they are glowing in the dark. Many species of nocturnal animals have this layer in their eyes.
I’d like to have the flashlight laser from Larry Niven’s Ringworld books. Can be used as a variable intensity wide beam flashlight or focused down to needle diameter to burn through rock, metal, etc
They didn’t mention the power supply but I think it s a tiny deuterium fusion reactor
The variable sword is wicked too. Looks like a jump rope handle and pressing the button causes it to spoil out invisibly thin wire that passes through a “stasis field” to make it indestructible
Like those 9000000000000lm zoomies…
Monomolecular lash (“m-lash”)?
I like SCI-FI :smiley: A liquid nitrogen cooled double walled light where the tail switch carries the motor and threw magnetic power circulates the fluid using a propeller, like in fish tank filters, It would have a combination of LED’s from the four centered SBT90.2’s behind a 60mm TIR lens. The outer part of the TIR lens would be a combination of other emitters functioning in a triangle pattern so you could have 5 sets of three emitters like, three UV, three 3000K three 5000K three Green and Three red. All running separately in there own groups for different needs so the emitter choices could be endless. It would be powered by two Tesla 54980 cells, can’t wait to here more on these!, With an led readout display of temperature, lumens, time, volts, all the goodies! It would also be USB and magnetically chargeable along with a portable folding solar panel for in field charging. Lets not forget to make it a power bank as well. Just what I could think of off the top of my head :smiley: I have high hopes for flashlight technology in the next 10 years :sunglasses:
Yep kind of like that. They discover a zero entropy technology called “stasis fields” that makes anything within the field indestructible and no time passes. So they make a handle with a tiny stasis field at one end through which the invisibly thin wire passes. Usually people extend it to about 1 meter length and it has a little red ball on the end of the wire so can see where it is (:
Some sort of super dense sci-fi power source, surely?
Didn’t Agent Scully have a Maxa Beam back in the day? And anything that looks like a lightsaber is surely a win?
Not sci-fi, but was just browsing through “Reaptown”, and it was refreshing to see this chick with a real flashlight, decent coverage and brightness, and not just some dinky AA Minimag or something.
